Gas Tank Help
Do i take all this crap off and plug everything off?
IMO a better option would have been to keep your 98 tank an to put dual pumps in it. Your fuel gauge will not read correct now. I'm not sure if someone has worked out a solution for that yet or not. The level senders are different, and the VCMs look for different calibrations from the units. I'm not sure which one is which, but on one the resistance goes up when the fuel level goes up, and the other the resistance goes down when the fuel level rises.
I do wish I'd have kept my old tank though. It would have been a breeze to gut the pump and just weld a proper sump on it. The 99+ tank was good for a single
Racetronix back then, after that I wound up sumping the plastic tank to get more fuel anyway.
