Map sensor help LS3 swap into 01' SS
Old Dec 20, 2016 | 10:24 AM
Darkness1982's Avatar
Default Map sensor help LS3 swap into 01' SS
I have searched and searched and find nothing but conflicting info.
I am new so please don't chew my ***, because i did try before asking to no-avail.
I have a 2001 SS with a LS3 swap and a D-1 procharger. I have a stock LS3 intake and it has the MAP sensor in the front.
I know they make an adapter harness and extension, but what i need to know is what i need to have to make this work when i trailer the vehicle 6 hours away to get a tune. I don't want the surprise of "it wont work, you are fucked."
I plan to run 10-12 pounds of boost and i am converting to E85 as well if that matters at all.
Help is greatly appreciated, as i am starting to go crazy with conflicting info!
Old Dec 20, 2016 | 03:47 PM
oscs's Avatar
If you need a throttle cable bracket for that LS3 intake hit me up.
Old Dec 20, 2016 | 04:27 PM
sschoeffler's Avatar
Just lengthen the wires. Cut, solder, shrink sleeve. You will also need to get a little piece of aluminum from Lowes or Home Depot and make a little hold down or boost will blow it out of the intake.
Old Dec 20, 2016 | 04:49 PM
oscs's Avatar
My throttle cable bracket also doubles as a MAP sensor pin down *cough*
Old Dec 20, 2016 | 04:59 PM
MY_2K_Z's Avatar
I need it in in Houston.
Old Dec 20, 2016 | 05:08 PM
ragtopz28's Avatar
I did this exactly...works perfect.
https://ls1tech.com/forums/attachmen...r-dsc04531.jpg
Old Dec 20, 2016 | 05:49 PM
Also get some of this. It's called techflex.
Old Dec 21, 2016 | 08:11 PM
No Juice's Avatar
Lets see it
Old Dec 21, 2016 | 09:56 PM
jimmyg's Avatar
Well if your going procharger , wouldn't you want a speed density tune and a 2 or 3 bar map? I would just call the tuner and ask him what map to run.
Old Dec 22, 2016 | 08:34 AM
oscs's Avatar
Originally Posted by No Juice
Lets see it
http://m.ebay.com/itm/LS1-LS2-LS3-LS6-L76-FAST-Throttle-Cable-Bracket-/252672791035?hash=item3ad478d1fb%3Ag%3A5yAAAOSwNSxVCJTG&_trkparms=pageci%253Aa08cc6b0-c853-11e6-b908-74dbd1807d63%257Cparentrq%253A26f3a2d91590a2a4f382c808ffd7a482%257Ciid%253A12
