Pre 05 6.0
Old Dec 20, 2016 | 06:44 PM
twotoxic13's Avatar
Default Pre 05 6.0
What is the most hp with boost someone has gotten out of a pre 05 6.0 SBE?
Old Dec 20, 2016 | 07:37 PM
olegreen94's Avatar
I made 673hp and 727tq on a 03 lq4 with stock rods Pistons and crank. On a On3 7875.
Old Dec 20, 2016 | 07:53 PM
twotoxic13's Avatar
Still have it? If not what happened to it?
Old Dec 20, 2016 | 07:55 PM
coltboostin's Avatar
The weak point here is the rods. I have made 860whp on Gen 3 rods. 150+ traps. 22-23psi. Bent them on an accidental overboost pull.
Others have made more i believe.
Old Dec 20, 2016 | 08:10 PM
HaterMaker's Avatar
what was your setup on the motor? And what fuel did you run?
Old Dec 21, 2016 | 05:48 AM
yenkomike's Avatar
there is a red z28 on here that has gone 8.80s with a gen 6.0 . its still running.
Old Dec 21, 2016 | 07:06 AM
olegreen94's Avatar
sold the car to start another project. I know there is people out there that has made a ton more power on gen 3 rods and think my setup had a little more in it. But it was enough to push a heavy Fbody 131mph in the 1/4 and that's with me granny shifting the stock t56 that had 261,000 miles on it and the stock 10bolt that had the same mileage on it. Sooooo I was pushing more than just the gen 3 rods to thier limits.
Old Dec 21, 2016 | 07:23 AM
RedRocketZ28's Avatar
The 2003 LQ4 has been in my car for 4 years now. Best 1/8th mile pass is 5.98 @ 119 off the footbrake. Never ran it in the 1/4 this year but I did last year and it went 9.54 @ 147.
I've had 4 different turbos on it, and two different cams in this thing and it keeps going. I am putting together a good rod/piston bottom end this winter though. I don't want to push my luck much more and want to go faster this year. I think my converter being loose up top is helping it stay together as well.
Old Dec 21, 2016 | 02:58 PM
twotoxic13's Avatar
Thanks for the info guys..
Old Dec 25, 2016 | 01:39 PM
twin on 3 Billett 67's. bone stock even Cam and intake Manifold. Cam2 from the lcoal gas station.
Old Dec 25, 2016 | 10:13 PM
slocaddy's Avatar
"Heavy Fbody" ...........lol.........
That's amazing the trans and rear took that abuse, but the miles are incredible. You musta been doin something right!
Old Dec 25, 2016 | 11:58 PM
Taubr Unit's Avatar
Iv went 8.86 @ 157 with my gen3 lq4, billet s483 on 21lbs and still hazing the tires, I'd say it's got a 8.60 in it on each it works good. It's all in the tune to make them live. I have about 25 passes on mine and thousands of street miles on it.
Old Dec 26, 2016 | 06:38 AM
yenkomike's Avatar
there is the car I was thinking of. 8.86 is running good on gen 3 rods. you must be keeping the timing soft at torque peak .
Old Dec 26, 2016 | 10:00 AM
Taubr Unit's Avatar
15 deg total timing on it and was tuned on 100 unleaded but run 110 to keep it even safer.
Old Dec 26, 2016 | 09:12 PM
olegreen94's Avatar
well heavy in the sense of it being a full weight car... but it had nothing on your caddy!!!
yes the tranny started whining before I got rid of the car but was still going strong at that power level. And the 10bolt lived because of lack of traction I assume.
But regardless the gen3 rotating assembly had 2500 miles on it or constant beating on it when I got rid of it 2 1/4 mile passes. So I wouldn't say I pushed it for a long time but it showed no signs of stopping. I just sold the car to start a different project.
