Manual Boost Controllers?
Old Dec 22, 2016 | 08:54 PM
rkupon1's Avatar
Default Manual Boost Controllers?
Are they all created equal?
What ones are you guys using?
Im gunna set up my turbo system with a mbc for now til i get the holley dominator system installed and up n running.
Besides, by than, i ll know more about turbo control with the Holley system and how to dial it in.
Jus looking to set up a simple/functional system for now. Thanx in advance
Old Dec 23, 2016 | 06:14 AM
JoeNova's Avatar
Restricted User
The cheap ones are pretty much all the same. Minor differences. My favorite is the Voodoo. My boost gauge doesn't bounce around once my wastegate opens with it.
Old Dec 23, 2016 | 11:17 AM
ls1charged's Avatar
anybody tried the "in cab" controller? was thinking about mounting one in my car so i can control boost without getting out of the car
Old Dec 23, 2016 | 07:28 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I thought everybody mounted their MBC in the car. Mine is in the console right next to the progressive meth controller.
Old Dec 23, 2016 | 09:22 PM
Beanslsxnova's Avatar
I run a hallman mbc. It's expensive for what it is but I have no complaints
Old Dec 24, 2016 | 08:07 AM
rkupon1's Avatar
Cool. I ve done so much reading last couple days, i ll prolly jus skip the foreplay n go right for it. Set it up with the holley boost control solenoids or maybe boost leash. It looks as tho the holley system has the same features as the boost leash, so i mite aswell run it like that from jump
Old Dec 24, 2016 | 09:53 PM
ls1charged's Avatar
idk maybe, i just had it mounted under the hood, wasnt sure how accurate it was running a line that long, say to your center console?
Old Dec 24, 2016 | 11:20 PM
gametech's Avatar
For any vac/boost lines more than a few inches long, I use brake line material. I don't trust all that flex in rubber tubing for long runs. Also, the smaller diameter means less volume to dampen the signal.
 Michael S. Palmer
Old Dec 25, 2016 | 06:09 AM
forcd ind's Avatar
I tried a couple cheap ones, the cheap brass one had a ball and spring-when I tried to adjust it, the spring would catch on the threads inside, so I wasn't real comfy with that-I looked at the Hallman, pricy, but then I found a killer deal on a Hallman, comp. with the inside cable kit on Ebay-it was used, but in perfect shape-I like it, boost is steady and adjustable
Old Dec 25, 2016 | 07:02 AM
yenkomike's Avatar
the turbosmart ones work pretty good for me.
Old Dec 25, 2016 | 12:09 PM
truckdoug's Avatar
i used the one that came with the "denmah kit" from VS
seemed to work just fine. I had more trouble figuring out which spring combo gave me the gate pressure i wanted. once that was sorted i could dial the **** between 7psi and 15 pretty easy.
