T04E big enough for stock?
Old Jun 23, 2004 | 04:06 PM
NJSPDER's Avatar
Default T04E big enough for stock?
hey gang,
i was wondering if a T04E woudl be enough to put 6-7psi into a basically stock + bolt ons LS1? i will be running through a front mount as well.
also, will i have to upgrade injectors? i am plannign to install a 255lph pump, what shoudl i do with teh fpr or shoudl i switch injectors?
the motor in question will be a low mileage '01 or '02 for my swap
thanks
tim
Old Jun 23, 2004 | 05:57 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
First, which TO4E?? Their are about a dozen different styles and models of that particular chassis.
Jose
Old Jun 26, 2004 | 05:25 AM
Taffy's Avatar
You can get the TO4E with a 67mm GT wheel. With the right exhaust housing, you should bea able to get close to 800 horsepower.
There is very little flow difference between the 60-1 compressor housing and the TO4E housing comparing the same wheels.
But Jose said that there were many TO4Es. I am talking about the standard TO4E that comes on most of the larger turbos.
