Compression Ratio
Old Jan 3, 2017 | 02:48 PM
blueracer15's Avatar
Default Compression Ratio
Hey everyone
Looking for advice on dished pistons for a turbo lq9, 317 heads and stock stroke LS9(0.051) gasket
I've don't all my research and calculations.
Weisco pistons claim -11 cc will get me 9.3:1 but all the calculators online tell me i will be in the 8.x:1 range. Looks like -5 to -8 cc will put me in the 9.2-9.5 :1 range with LS9 Head Gasket (.051) 317 chambers are 72cc
Was thinking weisco pistons -3.2cc (K398X05) and a 0.060 gasket from cosmetic would work but on their catalog it says the -3.2cc doesn't even change compression since it's still at 10.1
What are you guys running?? Looking to be in the mid or lower 9.x
Looking for real applications people have used!
Old Jan 3, 2017 | 03:47 PM
2000WS6TA's Avatar
i have the diamond -15cc i believe. my compression is just over 9:1. what compression calculator are you using? usually the piston manufacturers are spot on with CRs
Old Jan 4, 2017 | 10:53 AM
what motor, gasket and heads are you running?
i have checked the specs from the catalogs on all the major companies
diamond weisco mahle cp and ect but they only show to 70cc
the 317 head is 71 so i know it will be slightly lower the advertised
Old Jan 5, 2017 | 07:54 AM
2000WS6TA's Avatar
i have a thompson 370, untouched LS3 heads, LS9 gaskets. apparently the LS3s have somewhere between a 68-70cc chamber.
