Which heads?
Old Jan 4, 2017 | 11:34 AM
ls72nova's Avatar
I don't know, is there a way to tell with out pulling the heads? The block casting number under the passenger side head by the flexplate is 12567392. I can't find info anywhere on it
Old Jan 4, 2017 | 12:06 PM
408GT's Avatar
15#'s of boost is far from a max effort deal. FWIW Denmah made over 700 whp w/ a th-400 with 862 heads (same as 706's) with a china 88mm turbo. Unless you plan on making more than that, I wouldn't even open the motor up (except for a cam and valve springs). He had flat top pistons too btw.
Old Jan 4, 2017 | 12:23 PM
JoeNova's Avatar
Restricted User
Don't contradict yourself. You say you can only run 15# because of what the stock bottom end will hold, but say you want 799 heads for more power.
Either of those heads will flow enough to send those rods into sunlight. Spending money on new heads and possible machine work is a step in the wrong direction.
If your 04 has floating pin rods, you can run a LOT more than 15 lbs. Those rods starting popping up in 5.3s in 04.
Old Jan 4, 2017 | 12:30 PM
M_Minnick's Avatar
^^^^^This
Although you didn't state what turbo you will be running, 15psi will not be close to maxing out whatever you decide to go with. Use the heads you have and spend the money on the fuel system and tuning. The difference in HP between the head options you are looking at equates to around 1 psi of boost, which is basically free.
Mike
Old Jan 4, 2017 | 01:36 PM
ls72nova's Avatar
My plan is to run two 60ish mm turbos through an intercooler. I'm not sure which ones to get yet, I do have the intercooler picked out that will fit in the nose of the nova. I've been reading for days trying to figure which ones to get, any suggestions?
Old Jan 4, 2017 | 01:39 PM
JoeNova's Avatar
Restricted User
Depends on your price range.
I'd personally run Chinese GT35s from VS Racing.
Old Jan 4, 2017 | 01:41 PM
ls72nova's Avatar
I have a couple friends who have on3 76mm on there cars and they are happy with them. I was planning on using them but not sure which ones. I'll look up what you said though
Old Jan 4, 2017 | 01:52 PM
JoeNova's Avatar
Restricted User
Twin 76s for a mild 5.3 is very much overkill lol. Even with those small turbines they won't be much fun on the street.
Old Jan 4, 2017 | 02:12 PM
ls72nova's Avatar
When I said them, I meant turbos from on3 performance, my buddies both run single 76mm, lm looking at running two 60ish mm turbos
Old Jan 4, 2017 | 02:30 PM
408GT's Avatar
You still haven't posted a hp goal. Without that, you're pissing in the wind. While you're spending all this time reading, you aught to check out Denmah's threads. He's run about every china turbo on 4.8 or 5.3's.
Old Jan 4, 2017 | 02:35 PM
408GT's Avatar
If you really do want a max effort 5.3 deal, I'd look at what these guys did: http://www.yellowbullet.com/forum/sh...d.php?t=717938
Old Jan 4, 2017 | 03:27 PM
  #32
ls72nova's Avatar
I'm looking for 700rwhp plus with room to grow into more after I get this whole turbo thing figured out at the track
Old Jan 4, 2017 | 03:50 PM
  #33
Forcefed86's Avatar
Shine a light down the spark plug hole. (LED pen light works great) Should be pretty obvious.. Most of the gen3 stuff will have this cross on it if it's domed. Thats a good sign that you have the weaker rods as well.
Flat tops look like so.
Old Jan 4, 2017 | 05:29 PM
  #34
JoeNova's Avatar
Restricted User
I have crosses on my pistons and gen 4 rods.
Old Jan 4, 2017 | 06:11 PM
  #35
3 window's Avatar
Me too. Mine's a 2005 LM7.
Old Jan 4, 2017 | 06:31 PM
  #36
Beanslsxnova's Avatar
Im also in md and live close to MIR. You said you just got stationed here so I'm assuming you at Andrews Air Force base. There is a really good machine shop right in Clinton I've been using for 15 years. They do a ton of ls stuff and are very knowledgeable. The name is Clinton machine shop and there located off old Alexander ferry rd. Do not mess with any machine shops in Waldorf they are a joke.
Old Jan 4, 2017 | 06:36 PM
  #37
ls72nova's Avatar
I'm in the navy down at Pax River, when I was putting my bbc to gather I went to a couple and promptly went somewhere else a few times. Lol. I found an real old guy up towards Annapolis that was good. He does older stuff though. Where can I get it tuned around here. I can bring the car back home in MA and see if I can get DMC racing to do it. But that's a a 9 hour ride pulling a trailer
Old Jan 4, 2017 | 06:48 PM
  #38
No need for all that lol. I allways forget about pax river. There is a really good tuner at performance specialties in glen Burnie. Jeff is guys name.
Old Jan 4, 2017 | 06:59 PM
  #39
ls72nova's Avatar
Thanks man. You just put my mind at easy.... you go to MIR at all?
Old Jan 4, 2017 | 07:10 PM
  #40
not as much as I would like to, but I try to get down there once a month. I'm usually out riding around doing burn outs and stuff. I don't venture down in st Mary's to often though I live closer to laplata
