Intake manifold questin
Old Jan 4, 2017 | 05:13 PM
Hypforlife32's Avatar
Default Intake manifold questin
Whats up guys, over the winter i am changing a few things on my setup. I currently have a ls6 intake manifold with a stock throttle body. I feel like it is hurting my setup but i could be wrong. I am looking to switch but im not sure which direction to go. I do street drive the car alot. It is a th400 car so when im in power its between 5800-7000 rpm. I would like a 90mm throttle body which i feel the car would benefit from big time but lost on what intake. I dont want to cut the cowl. Ive seen a few intakes but would like opinions/dyno results from switching . Turbo car.
ly6 408. - 9.7:1 Comp E85
afr heads.
s484
Old Jan 4, 2017 | 09:52 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If the little info you provided is correct, your tune must be off. Otherwise, you wouldn't be asking these questions. Your intake and TB are not a problem on ANY turbo car that ever sees street duty. The fact that you are spinning a 408 turbo to 7krpm leads me to believe you are either the most jaded horsepower junkie alive, or you are doing it wrong.
Old Jan 4, 2017 | 10:18 PM
it spins to 6800 at the most. Made 715whp at 11 psi on the 28 radial. Just was looking at options. Lol. I do like hp though.
Old Jan 5, 2017 | 06:34 AM
JoeNova's Avatar
Restricted User
More boost is free.
Old Jan 5, 2017 | 07:46 AM
408GT's Avatar
In before Mark's Mustang with a 403 ci w/ stock 317 heads and LS-1 intake w/ stock throttle body and home built th-400 went 7's comment.
Old Jan 5, 2017 | 07:59 AM
sbcgenII's Avatar
Mighty Mouse went 8s with a ls6 intake :p
Old Jan 5, 2017 | 08:19 AM
svslow's Avatar
But who would want an intake that allows you to close the hood?
Old Jan 5, 2017 | 08:27 AM
JoeNova's Avatar
Restricted User
In Before "Stock48 went 7s with a stock displacement 6.0 with stock truck intake/throttle body off the footbrake in a 3400 lb street car".
Old Jan 5, 2017 | 08:54 AM
87caprice318's Avatar
And I went "nowhere because my first time out on the street I blew my block to pieces because of a damn vacuum line"
Old Jan 5, 2017 | 06:44 PM
rpturbo's Avatar
Isn't this how it always seems to go? 9 thousand people can go crazy fast on stock 250,xxx mile stuff, but when you (or I ) try, it goes to ****!
Old Jan 6, 2017 | 07:39 AM
408GT's Avatar
Because the big thing most people (including myself) get caught up in is "do I need a bigger this, or the best that", etc. and they miss the fact that everything has to work together as a combination to work correctly and go fast.
Old Jan 6, 2017 | 07:42 AM
JoeNova's Avatar
Restricted User
I like it when everyone all buy the same camshaft or intake whether its a 4.8 or 6.2 and expect it to work "Because it did for someone else". lol.
Old Jan 7, 2017 | 01:50 PM
MIGHTYMOUSE's Avatar
