Truck manifold injectors
Old Jan 5, 2017 | 06:41 AM
forcd ind's Avatar
Default Truck manifold injectors
Since a lot of guys are running truck manifolds, I know someone can answer this, lol
Are the truck injectors the same as like LS1 injectors? I will need to upgrade to like 60's for mild boost, and also use a plug like LS1's use-I think the truck injectors have a diff style plug-I am using the Holley HP, so would like the harness to plug in.
Old Jan 5, 2017 | 06:43 AM
JoeNova's Avatar
Restricted User
Plugs are usually different. You can use a longer LS1 injector, you'll just have to space your rails out with spacers/washers, etc.
Old Jan 5, 2017 | 07:53 AM
forcd ind's Avatar
What about LS3 injectors, would they be the same size? I have a set of them with the LS1 plug I used when I had LS3 heads and intake on another car. The LS3 injs. are shorter than the LS1's, but I think they took a diff size o ring.
