Turbos for autocross?
Old Jan 9, 2017 | 04:41 PM
Black_Sunshine_99's Avatar
Heat soak is only an issue if you do not build in adequate heat cooling capacity for the system.
And exactly...are you building to win..or just have a ******* good time ? You have the turbos already there so use them. If you hate it then take them back off lol
Just because I don't know, do you mean the engine cooling system or the cooling system for the blower or both?
I think if the OP thinks he'll be competitive auto-crossing a brick like a C10 against dedicated lighter cars then he has other issues lol.
Old Jan 9, 2017 | 04:48 PM
stevieturbo's Avatar
Proper heat management applies to everything.
But as your post was relating to the blower itself, obviously that means the chargecooling aspect.
It seems many kits offer small water cooling capacity, small lines, crappy pumps and no management of that water cooling. If there are specific needs for the vehicle then more effort will need put into all of these areas.
Or for the likes of low speed stuff, if that's what this is then some of those interchiller things would be a huge improvement for keeping cool air.
Old Jan 9, 2017 | 05:58 PM
Project GatTagO's Avatar
Sell LS3 and get a LSx 454. NA is best for autocross...
Andrew
