meth inj
Old Jan 8, 2017 | 06:51 AM
sbf2's Avatar
Default meth inj
hi guys im just getting into the turbo stuff and have a few questions about meth.
1.on average how much hp increase.
2.is there a bad side using it
3.example lets say i make 750rwhp pump gas or race gas with a turbo then add meth would it make 900rwhp then,just asking
Old Jan 8, 2017 | 06:55 AM
forcd ind's Avatar
Prob no average, make as much as you want-but I would say double what it is NA as an average.
Bad side could be costs if you don't have fab skills
Meth wont bump up the HP like nitrous, it allows some safety in tuning for more HP
Old Jan 8, 2017 | 08:32 AM
3 window's Avatar
Are you referring to running meth as your primary fuel or as supplemental injection like the title states?
Old Jan 8, 2017 | 11:03 AM
sbf2's Avatar
supplemental,fuel gonna be 93 oct for street and e85 or race gas for the track undecided
Old Jan 8, 2017 | 12:49 PM
lmt0705's Avatar
It doesn't add HP. It allows you to run more boost/timing safely. It should be used as a fail-safe, not a primary fuel source. What I mean is have adequate afr on your pump gas tune first then the meth is the added security blanket. If you tune full bore with the meth kit and for some reason it fails you'll be looking thru your pistons
Old Jan 8, 2017 | 02:10 PM
tim wellington's Avatar
Default meth
spec In sig on 15lbs afr 11.2 ,with 50/50 afr fattens up to 10.8 .I can fill meth in seat of my paths when I turn it on .I think most from the 20 degree iat drop
