Nova turbo Gear choice ?
Old Jan 6, 2017 | 07:08 AM
jasonsnova's Avatar
Default Nova turbo Gear choice ?
OK guys I'm in the middle of my turbo build , car is a 71 nova ,sbe gen3 lq4, ls3 heads ,ljms stage 1 twin turbo cam, holley hp efi, D&d built t56 6speed which has the 2.66 1st and .5 6th, turbo is a BW s475 t6 1.32 AR, car is a street car that might see strip 1 -2 times a year. Originally I started build as a NA , but then decided on turbo as the car currently has a 9" with31 spline Moser axles Strange center,Detroit trutrac, and 4.10.....I know the gears need to go. I would like everyones input on gear choice.....right now I'm thinking 3.50 or 3.25. Street tires are 315/30/18 , for track I'd probably run some taller drag radials. Hp goals are 650-700rwhp.
Here is current state of build
Old Jan 6, 2017 | 07:23 AM
svslow's Avatar
Generally a gear is chosen to put you at a desired RPM at the end of the 1/4. I'd think with the T56 you would want to keep it out of 5th gear at the end of the track. What size tire would you run at the track?
Old Jan 6, 2017 | 07:40 AM
JoeNova's Avatar
Restricted User
I'd recommend finding one of those T56 speed calculators and going from there. I wouldn't go any higher than a 3.55 with that short of a tire on a turbo build. 3.25 is probably right on the money.
Old Jan 6, 2017 | 07:57 AM
jasonsnova's Avatar
Got no idea on what tire I'd run at the track but i have plenty of room the car is mini tubbed and has full ride tech suspension. I actually have alot of room left even with the 315's..
I was also thinking 3.25.....but was also thinking it might make 6th unuseable unless I'm going 80+...but I guess that's no biggie
Old Jan 6, 2017 | 08:19 AM
truckdoug's Avatar
depends on what size radial you go with. i have 3.50's and use a 28" tire and it seems okay. if i could change gears for free i'd do a 3.00 or a 3.25
Old Jan 6, 2017 | 08:50 AM
jasonsnova's Avatar
Thanks guys.....3.25 it is.....just hard to be sure being I was always a NA guy and those are some high gears for a NA car
Old Jan 6, 2017 | 01:50 PM
rkupon1's Avatar
Once that turbo lights off, your prolly gunna love having more gear. My research has also led me to 3.50s or even 3.25 should be fine. If its more if a street car n it has 6spd, you defly have options
Old Jan 6, 2017 | 01:59 PM
3 window's Avatar
You won't believe the torque the turbo setup will produce. I had a friend bet me $100 my car didn't have a 3.08 in it. I offered to crawl under to pop the cover and he backed out. (I let him keep his money)!
Old Jan 6, 2017 | 06:05 PM
Beanslsxnova's Avatar
I switched from 3.25s to 3.50s a while back trying to help my 4.8 get out of the hole better. Over the last winter I built an ls1/s475 combo. On 12#'s of boost 14* of timing with 3.50s on 255 raidial in 3rd gear "th400" it will blow the tires clean off from 60 roll. Haven't had it to the track yet but on the street 3.50s are to much with any power and spirited driving.
Old Jan 8, 2017 | 02:15 PM
jasonsnova's Avatar
60mph roll on burn outs sound fun....lol. I'm a ways out for that but slowly making progress!
Old Jan 8, 2017 | 03:50 PM
Well My seat belts broke, and I don't have a cage. So it's fun and scary at the same time haha
