MSD 8287 LS2 coil on a LS1 engine
Also, thinking about just going the stock LS2 GM coil route(for a truck LS1 remember), can someone offer help getting the truck coil and harness part numbers to take the the Chevrolet dealership?
Thank you big time!
I would like to know the one you have on your truck ?
The "sub" harness could need a change as the LS-1/LS-2 connectors are of different size/pin-outs.
The max boost I state is 15-16 though reports of 22, with "closed gap", are common.
The coil you have is a 58mj energy output, my guess of your fitted item.
My IGN-1A coil is the most powerful choice, the choice of Andy Frost "Red Victor" @ 55 .lbs, a Meth fed head.
Your comment of "hesitation" is most likely from another cause, though to "OPEN" the plug gap as suggested above, would be a good choice.
Would you be able to better describe your problem ?
Lance
I have done pressure testing on everything, Soap and watered a river acrosse the engine to find leaks, and yes i have check valves on my vibrant performance catch can installed exactly as instructed. This build has fought me every step of the way. So I want to try to get more spark, which "Megasquirt" claims the LS2 coil puts out 80 more Milijules than the LS1 hope that would solve the misfire codes and hesitation. I am stumped why air is blowing out the oil return and how to fix that and fix being down on power.....
99% of the parts are interchangeable, but it does determine what the truck came with from the start. LS1s did not have heatsink coils, where as the trucks in 2000 were available with them. That's why I asked.
The stock heatsink coils outperform those overpriced MSD coils. They might even be causing your issue.
