Another A&A Build
Old Feb 10, 2017 | 07:26 PM
Detoxx03's Avatar
I would do at minimum 8 rib
Old Feb 10, 2017 | 09:19 PM
FEAR LS's Avatar
8 rib upgrade/conversion = $1100 to do it "right". Just not in the budget now. Already have the 6 rib setup sitting in the garage... Might keep the 3.8" pulley on it for now... Lol No I won't
Belt slippage might keep those MLS gaskets in tact...
Old Feb 11, 2017 | 08:36 AM
jimmyg's Avatar
Your definitely going to need a return style fuel system with bigger lines(-8 feed -6 return) with twin 340s.
Old Feb 11, 2017 | 08:54 AM
FEAR LS's Avatar
What makes you say this?
Old Feb 11, 2017 | 09:02 AM
The Cartel's Avatar
Listen to someone who has done it... Me! You'll be fine with the mls gasket, you will want to upgrade the alternator bracket to the newer version, also while your there get rid of the plastic power steering pulley and get a ls2 c6 pulley. I did that on a stock ls1 short block and ran mid tens
Old Feb 11, 2017 | 07:31 PM
FEAR LS's Avatar
Thanks man, I planned to upgrade those things. The A&A instructions say to do so as well for the earlier Vettes.
Old Feb 12, 2017 | 06:14 PM
FEAR LS's Avatar
She's dirty as all hell, but I figured I'd attach some photos. Have a lot to install. lol
Old Feb 13, 2017 | 06:36 PM
The Cartel's Avatar
Nice! Now get to it! lol
Old Feb 13, 2017 | 10:04 PM
jimmyg's Avatar
Twin 340s is too much fuel for the corvette filter/ reg. It will be fine on 1 340 , but when the other one kicks in, you won't get the volume of fuel you need. I ran 1 340 with the corvette set up . When I went supercharged, I switched to a single 450 , return style . 11lbs boost , no problems. You have a very nice set up planned, why risk going lean?
Old Feb 14, 2017 | 09:23 PM
FEAR LS's Avatar
I'm just trying to understand the Corvette fuel system better.
What makes you say twin 340's is too much fuel for the stock filter/regulator? Like what have you done to verify this?
A single 450 won't get the job done, in my case.
Old Feb 15, 2017 | 05:41 AM
jimmyg's Avatar
I was told by a few different people while building my car, including racetronix. This was with a single 450, never mind twin 340s. Send them an email, see what they say.
Old Feb 15, 2017 | 11:22 PM
  #32
JakeFusion's Avatar
Super Hulk Smash
ECS has the best bolt on fuel setup for the Vette. I'd just go with that.
Old Apr 6, 2017 | 04:06 AM
  #33
LSxPwrDZ's Avatar
If you are wanting only 700-750 DJ HP you'll be perfectly fine with a single 450 pump on gas. 6-rib will give you a headache at that level but we've done it before with a D1SC on a C5Z. The car had an NA Futral F12 cam in it with some TFS215 heads. We put 110 race gas and a single nozzle meth kit on the car and it made 760hp on 13-14psi. We were pretty aggressive with timing to get that power on that combo but it was a runner and lived.
