Using a T fitting as a merger. Advised
Old Jan 31, 2017 | 05:30 PM
Ogoz23's Avatar
Default Using a T fitting as a merger. Advised
Hey guys , im building my hot pipe and my merger looks like a T / Y .. I want to redo the whole hot side using schedule 10 stainless now. I want to get your opinion in using that T fitting in the picture as a merger . Do you think it would work? I'm asking because it is exactly a T and I know a Y has better flow characteristics but not sure if it would affect anything . Thanks in advance
Old Jan 31, 2017 | 05:38 PM
wildcamaro's Avatar
Not optimal but it will still work, if you saw my merge that t would be considered mint lol
Old Jan 31, 2017 | 08:42 PM
Ogoz23's Avatar
I wonder how much a T like that would affect the flow .. im sure a y is better but I wonder if this is detrimental
Old Jan 31, 2017 | 10:12 PM
truckdoug's Avatar
whats wrong with the tube the way you got it now? looks good from here
Old Jan 31, 2017 | 10:14 PM
Ogoz23's Avatar
Well is 16 gauge aluminines steel ... and I'm scare it's going to crack with the weight of the turbo over time ... maybe I'm over thinking it .
Old Jan 31, 2017 | 10:25 PM
truckdoug's Avatar
put a strut from the turbo up pipe flange down to the frame. i used some 2" wide 3/16" bar
Old Jan 31, 2017 | 10:30 PM
Ogoz23's Avatar
Maybe I'll just do that and call it a day .. I'm 90% done with the crossover so I hate to start over again
Old Jan 31, 2017 | 10:40 PM
truckdoug's Avatar
yeah get that **** rolling sooner than later. dont get stuck in the "building a turbo kit for 6 years" trap
Old Feb 1, 2017 | 06:33 AM
stevieturbo's Avatar
Many people have done much worse. If it works out easier for you, just fire away.
Old Feb 1, 2017 | 01:57 PM
roastin240's Avatar
Like they said build a support bracket. Unless the entire thing was schedule 10 minimum and close to the engine, not hanging as a lever arm and cyclically fatiguing until it cracks, then I would always build a support bracket.
Old Feb 1, 2017 | 02:24 PM
yenkomike's Avatar
https://cimg5.ibsrv.net/gimg/ls1tech...1231285237.jpg
I used a merger like your's in your upper pic and it works great . this one is cheap jegs tubing and has held up good at 20 psi running 9.40s on a 5.3 on3 78/75 setup.
Old Feb 1, 2017 | 02:27 PM
Ogoz23's Avatar
I welded up everything today, this is how it came out.
