How far can I take deka 80's on e85?
Old Mar 2, 2017 | 06:55 PM
truckdoug's Avatar
in before someone posts the white paper about E50
Old Mar 2, 2017 | 08:40 PM
Forcefed86's Avatar
~Bam!
Attached Thumbnails How far can I take deka 80's on e85?-20170302_203756_zpsiejdd7fg.jpg
Old Mar 2, 2017 | 10:14 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by ScottyBG
If you find you are running out of injector on E85, there is a really easy, zero cost way to extend them about another 10%. Blend your E85 back to about E70 with premium unleaded E10. 4 gallons of E85 to 1 gallon of E10 gives E70. There is virtually no difference in knock resistance between E70 and E85. You get a little more cooling from the E85, but it is really a very small difference. Normally E10 is available on the same pump with the E85, so blending it really is no big deal. There are a few other advantages to E70 as well, like it starts quicker on a cool day, and if it is a street car, you get about 10% more range from a tank of gas.
The group of people that chose 85% as the blend of ethanol in E85 fuel had the intent of replacing as much gasoline as possible with ethanol. After all, the intent of this fuel was to replace foreign oil, and clean up the environment, not fuel our tire burning machines. In fact it is a bit of an ironic deal that we are using this "clean renewable fuel" in our cars without catalytic converters, and our large overlap cams spewing out unburnt hydrocarbons out into the environment. If you took into account other factors, like cold starts, fuel range etc. E70 would have been a far better choice.
The intent of this fuel was ALWAYS solely to increase farm subsidies. Corn based ethanol (the type in the U.S.), offers no environmental benefits, nor does it replace any foreign oil. By the time you grow, process, distill, and transport corn ethanol, you have polluted the environment more than digging dead dinosaurs out of the ground. Either way, the higher octane racing aspect was a side benefit to us that nobody else cared about. End rant.
Old Mar 3, 2017 | 01:30 AM
ScottyBG's Avatar
The environmental benefit is that my engine doesn't crack a piston then put a rod through the side of the block and dump my dirty engine oil on road. It also reduces noise pollution, because I'm not cursing about cracking a piston.
Old Mar 3, 2017 | 02:55 AM
RonSSNova's Avatar
"How far can I take deka 80's on e85?"
All the way to the finish line!
What is the Stoich of E70?
You certainly can jack the base pressure up. But you need to know where the pump really begins to lose flow vs. pressure.
Some are better than others.
And of course watch IDC and AFR closely.
I added a second pump to help me push my ID1000's a bit further. E70 does sound attractive.
Ron
Old Mar 3, 2017 | 12:05 PM
roastin240's Avatar
Im about to find out...Dual -6 feeds and dual walbro 450 in tanks...I plan on 60-70psi base FP and probably mixing some premium fuel to end up between e50 and e60 somewhere. I have ethanol sensor feedback though so I will be stylin
Old Mar 3, 2017 | 01:42 PM
ScottyBG's Avatar
Here is what I use for stoich on various blends.
E98=9.0
E85=9.8
E80=10.1
E75=10.4
E70=10.7
E65=11.0
E50=11.8
E40=12.4
E30=12.9
E20=13.5
E10=14.0
E0=14.6
Old Mar 3, 2017 | 02:27 PM
truckdoug's Avatar
nice, what is your goal power/et wise? What engine management system do you use?
Old Mar 3, 2017 | 10:09 PM
gametech's Avatar
It would seem that you have a solid understanding of the benefits of e85.
