Nitrous to turbo
Old Feb 4, 2017 | 08:31 PM
M1SERY's Avatar
Default Nitrous to turbo
Well finally going turbo, I have been runNing nitrous oxide for several years on my car , and now going turbo , going for Huron speed v3 keeping the ac, PT88 ,
What I'm hung up on is my motor , 370 , with tf 235 heads is at 11.4:1 , and thats with ls9 head gasket, will this work on 93 pump gas and a water meth injection system?,
Take it easy on me I'm learning as I go , I know the compression is high, like to get some input from knowledgeable force induction gurus
Thanks in advance
Old Feb 4, 2017 | 10:32 PM
JoeNova's Avatar
Restricted User
You won't be able to run more than a few PSI with 11.4:1 on pump gas.
Either swap to large chamber heads or run E85.
