To intercooler or no that is the question.
Old Feb 14, 2017 | 09:47 AM
  #41
gtistile's Avatar
My theory (which might be totally wrong) is that teh sensor is picking up heat from intake/block. So looking the the temperature readings alone won't ever be correct. If you have a way to look at actual power (trap speed or dyno) and don't see a major improvement with the pump on/off. You'll know the sensors are probably correct.
temps go up to 230* during a pass and are back under 100* by the time I get on the return rd. I can't see an intake manifolds temp jumping nearly 200*, heat soaking the sensor quick enough to give high readings, all while having cool air rushing over the sensor if we are to assume it's actually cooling the air. Does that make sense?
Old Feb 14, 2017 | 09:47 PM
  #42
3 window's Avatar
Originally Posted by JoeNova
Also, Silver_82 was running a stock bottom end 5.3 on E85 with no intercooler, making 31 PSI and running 8.teens in the quarter.
E85 can be forgiving with a good tune and a well planned out setup.
Truck's got a one off A/W in the intake.
Old Feb 15, 2017 | 06:28 AM
  #43
JoeNova's Avatar
Restricted User
He might now, but he didn't a couple of years ago when he took the SBE record. He even mentioned non-intercooled in the setup details.
https://ls1tech.com/forums/forced-in...-19-167-a.html
His new setup is nuts lol.
