Fuel Filter & Dual Pumps Manifold
Old 02-14-2017, 10:28 PM
Forcefed86's Avatar
Originally Posted by aggie91
I don't know this first hand, but based on the spec sheets for this Bosch check valve and the AEM 380 pump, these will not work with the AEM Pumps.
The Bosch check valve works with a pump outlet of M12x1.5 and the AEM pumps have a -6 ORB fitting for the outlet.
Good catch! I assumed they would be the same as the 044. Guess we are stuck with the "Y" blocks.
Originally Posted by 2JZFC
That billet Y block is exactly what I am looking for but not sure if the 76mm between the 8AN centers match the dual pump brackets. Anyone know? Also want to find a US seller since I don't trust shipment from China being timely.
Any thoughts on compact, but not restrictive pre-pump filters.
Why are these blocks designed to use the check valves? Are they actually using the check valve or just because that's how the 044s are delivered?
I think they were just all designed for the 044.
Here's a US seller.
http://www.ebay.com/itm/262494651123...%3AMEBIDX%3AIT
No idea on compact pre filter's. I used a surge tank with no filter on the Aem 380. It's fed by the OEM intank sock pump.
Let us know what you come up with!
Old 02-14-2017, 10:42 PM
2JZFC's Avatar
This is how I plan on doing it, minus the surge tank and with AEM 380s. The Y setup will be more compact with AEMs since the check valves are built into the 8AN fitting.
http://www.ebay.com/itm/3L-RAW-ALUMI...RYcyeb&vxp=mtr
Old 02-15-2017, 05:45 AM
3 window's Avatar
Kinda of a bad pic, by here's how I did mine. This is with 2 mock up 044s. It's just a log with 1/2" npt ports. A 12an feed into the side, the two pumps each have a 8an coming off to a wye which attaches to a 10an all the way up. I run two AEM 380s on E85. No issues all last summer. The fittings on the AEMs are different threads than on the 044s.
Old 02-15-2017, 11:37 AM
stevieturbo's Avatar
Believe the 044 check valves will thread into the AEM pumps. at $15 each that be something to look into.
http://www.ebay.com/itm/New-Genuine-...NYm3ys&vxp=mtr
Then run one of these $20 twin pump adaptors.
http://www.ebay.com/itm/Billet-Alumi...NXoAHl&vxp=mtr
For $22 shipped you can buy 2 of the bosch clones and get 2 pumps for $14 and rob the check valves off them.
http://www.ebay.com/itm/New-Universa...3D161919515877
Or these that claim 300lph for a bit more.
http://www.ebay.com/itm/300LPH-Unive...3D112235212882
044 check valve will not screw into the AEM pump.
AEM uses -6 outlet on the pressure side and -10 on the intake side.
Bosch 044 uses M12 on the pressure and M18 on the inlet.
If you really must retain the check valves for a pair of 044's for whatever reason, then there are already options out there
http://www.ebay.co.uk/itm/Twin-Bosch...item58a4e1aa3c
Old 02-15-2017, 11:38 AM
Originally Posted by oscs
That tri pump picture makes me cringe lol. I hate seeing union fittings that T instead of Y. That fuel has to make 2 90* bends before it exits. I'm sure they work well but it just gets under my skin thinking about the pumps fighting each other.
It isnt a 3 pump, it's 2 pumps feeding into a filter. A shitty filter that will flow **** all too.
But yes, whilst compact, still **** for flow. That said, if the orifices are big enough it probably wont impact overall flow too much anyway
Old 02-15-2017, 11:43 AM
Anything against all the usual filters ? Holley, Earls, Aeromotive, etc etc etc ?
Some people obsess about check valves. They are not needed. If you want an 044 to flow more...throw away the check valve, the same will apply to the AEM.
It does mention the difference in their instructions, but dont have them to hand.
Obviously if you want to stage the pumps then you would need check valves somewhere though
Old 02-15-2017, 02:50 PM
oscs's Avatar
I was just referring to the tri pump picture. Not that it was 3 pumps. I agree though.
Old 02-16-2017, 09:14 AM
93hatch's Avatar
I have one and a 255 just going into a y. The check valve for the 380 is fn tiny inside, I just used an open fitting instead. I ran out of pump with dual 255s but I'm fine with the one 380 added
Quick Reply: Fuel Filter & Dual Pumps Manifold
