Spal Fan with ATI High Temps
Old Jun 25, 2004 | 10:49 AM
MstgKillr's Avatar
Default Spal Fan with ATI High Temps
I already have the 16" Spal fan 30102036 that is rated at 2360 CFM. Spal recently released a more powerfull 16" version 30100845 that is rated at 3100 CFM, but it also pulls 30 amps compared to the 20 amps my current fan pulls. I live in Florida and I have recently noticed that my temps are getting high while in traffic with the AC on. I thought that I had my temp issue fixed with the current fan. Do you think the extra CFM would make much of a difference? Can my car handle the extra amp draw from the new fan? Should I just upgrade the radiator instead? Will the BeCool fit with a Procharger? Thanks
Old Jun 25, 2004 | 10:52 AM
NA$TY-TA's Avatar
How high of temps are you seeing? What temp is your fan set to come on at? I still have the fan that came with the kit and its working fine in this Texas heat so far........ i dont have A/C either so its not blocking my Radiator........ Are you going off the stock temp gauge in the car? If so they are not very accurate.
Kyle
Old Jun 25, 2004 | 11:25 AM
MstgKillr's Avatar
The temp will get to 220* but I will start moving or turn the AC off before it goes any higher. I would hate to get stuck in a traffic jam.
I don't know exactly when the fan turns on with the AC off, but with the AC on it always runs.
Going off of a scanmaster and an Autometer guage.
I also have a problem with the AC blowing cold air espically when moving, its better while parked.
Old Jun 25, 2004 | 12:19 PM
BIGBOS's Avatar
I have a CAS 4" radiator w/that Spal fan, with an iron block in the summer heat I have no problems at all....
Old Jun 25, 2004 | 02:46 PM
Blackbird's Avatar
the bigger fan will certainly help and the draw should be fine.
at one point I was running 4 fans with no issues with my powerdyne setup.
Old Jun 25, 2004 | 03:12 PM
Inspector12's Avatar
TT-TECH Veteran
I have a 6 month old Be Cool radiator I am selling it was on the car for about a month when the guy decided to sell his car asking $300+shipping let me know it you thing it will help your cooling issues it fits in the factory location and has all the brackets for the A/C condencer ETC... It is the satin finish and is all aluminum. It is for a 6 spd no provisions for an automatic cooling lines.
Old Jun 25, 2004 | 05:59 PM
Unusual T/A's Avatar
where is pearland located? I may be interested
Old Jun 25, 2004 | 06:03 PM
TT-TECH Veteran
I am in the Houston area.
Old Jun 28, 2004 | 09:35 AM
GT30's Avatar
Just noticed your post, I had the same problem with mine, (we seem to have a lot of the same mods) my temp gauge and oil gauge were both getting into the 220-230 area, so as per a friends suggestion, (he does a lot of drag racing and knows a lot of tricks) I drained the radiator, installed a mixture of 25% coolant, 1 Purple Ice additive and Pure destilled water.
Went out this weekend with the A/C on runned hard and never got past 190 degrees!
Hope this helps.
GT
Old Jun 28, 2004 | 10:34 AM
69firebird's Avatar
do you have any pictures of that radiator inspector?
i may be interested, is it stock location?
thanks
ed
firebird455@onebox.com
Old Jul 2, 2004 | 01:14 AM
WS-6_2002's Avatar
What about an electric waterpump?
Old Jul 2, 2004 | 06:27 PM
Black LS1 T/A's Avatar
Moderator
GT
How much is this in gallons or quarts?
Old Jul 4, 2004 | 07:26 PM
TT-TECH Veteran
Sorry about the pics guys I forgot I just got busy and just looked at my email notification. When I get off in the morning I will take some and post them up.
Old Jul 6, 2004 | 06:57 PM
TT-TECH Veteran
Default Be Cool radiator Pics
Here are a few pics to show it and you can see that it is in good shape and does not have a lot of bent fins or anything let me know if you are interested.
Old Jul 6, 2004 | 07:07 PM
BIGBOS's Avatar
I would get that one or a CAS, the CAS looks a little bigger compared to the pics, I have one picture of it in my webshots....
CAS will probably take 6 months to get to you though
Old Jul 6, 2004 | 10:06 PM
Bryan Wilkinson's Avatar
I think it is important to note, that the humidity level on the east coast makes the situation much worse than those fellow fbody owners out west. Humidity adds anywhere from 15-20 degrees to the actual rated outside temp.
Just a little tid bit.
Old Jul 7, 2004 | 05:05 AM
Moderator
Yeah... it's making me question my decision to do the Iron Block.
Old Jul 7, 2004 | 07:27 PM
TT-TECH Veteran
It is a nice radiator and all the stock equipment hooks up like the factory stuff and fits in the factory location just so everyone knows that might be wondering.
