Bw s400sx 75mm
Defiantly not needed on the average street/strip build IMO. Even the 4 ports aren’t needed as they are quite a bit more expensive. With a 3 port MAC valve I can run 8-30+lbs with 2 38mm WG’s on a 370. Or 1 44mm gate on a 5.3.
Once you get into competition and class racing I can see wanting a C02 setup.
I also think having a time based boost controller is a must for anyone wanting the max out of their car at the track.
Yes you can achieve the same amount of total boost several different ways, but with a controller like the Boost Leash you have much more control over how you get there and when it gets there.
