TFS/Jegs 228/230 Cam Turbo Results?
Finally getting around to building my foxbody. It's a Gen III with Gen IV rods 5.3, Pac 1218, arp head bolts, new stock mls gaskets, swap pan, and that stage 2 TFS 228/230 .585/.585 on 112 cam. I have a 4l80e, stock ecu, and harness I plan to use.
I know Denmah dynoed 1 car with that cam, around 650rwhp on a 6.0 with china 83/88? turbo. Do we have any other turbo results?
I know the cam isn't ideal, it seems there isn't a ton of turbo info with it. Is the LSA too narrow, too much cam for smaller china hotsides? I'm thinking of running a 96mm turbine S475, either 1.32 T6 or possibly a large T4 from Forced Inductions.
There is ALOT of guys on Sloppy using them with good success. I personally run a LJMS cam so I would just go with the Stage 2 (go to for everything lol) but you would be totally fine running it. The S475 would be a killer turbo to run with the cam bc of the turbine size. You cant go wrong with T6 or getting a T4 from Jose at FI
