Dayco Polycog belts, any good for a s/c belt???
I would figure it's around the same price, 30-35 bucks. I don't know the price because the fools at autozone never gave me one
I didn't check on the gates belt but I am sure that is the same as the NAPA belt since Gates makes all the belts for NAPA...
53-1/8 long.
Let me get you some pics of the LM-1 in the car
I am sure they are pretty accurate, accurate enough for tuning purposes. It was a very easy install, but I need to get a RPM signal to it so I can get some RPM/AFR graphs printed up.
J
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
53-1/8 long.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
J
53-1/8 long.
J![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
53-1/8 long.
J
Dirty, More info on that one please... LInk? Pm me if needed and not a sponsor...... Thanks
Kyle
yep the dynojet piece is a good one, but I got mine use once for 265 shipped, can't beat that with a stick![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Pics coming up lol.
J![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Pics coming up lol.
J
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
No ya cant beat that $265 you paid. I believe its $350+ S%H for it new. How much is the other one Dirty?? Or anyone who knows?? Jer, what size slicks and skinnies you running in that vid? Tire and rim sizes please?
Kyle
black bird, yes i do have the wideband commander ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
i heard that if you have a shift light it might interfere with the signal, another place to hook it up is to one of the feed lines to a coil . go to their homepage for some updates they have there.
nasty, check the dynojet website for info, if you can't find it tell me and i'll pm you the address.
the kit is really great, you get soo much with it; first off it comes with a 2-1/16 analog A/F guage, the sensor, the contor box thingy and all the wiring and plugs you need. it also comes with a usb vable to connect your laptop to it. and incase you don't have a laptop, they supply a 9 volt battery plug so you can remove the control box or module or commander ( call it what ever you want) and take it to your pc and down load the info on to that after you recorded a log file.
other interesting tidbits: you have a warninig light connection where you ca trigger a warninig light at any rpm, throttle position, and A/F or any combination of the three.
the kit also has a window switch built in the is triggered likt the above. you also can log a seperate data stream ( or something like that).
the commander logs A/F and throttle pos. and rpm. you can either use the supplied guage to see what is going on or hok up your laptop and read it from there. after you are done you can convert your log file into a text file for easier review.
kit also comes with an o2 sensor bung and a plug for it incase you want to remove the sensor.
man i feel like a salesman after writing all that!
Originally Posted by NA$TY-TA
What did ya do Jer..?? Run out there and take them real quick?/ ha ha
Kyle
Kyle
Lol I did feel a lil bad for paying that much but that is what the guy was asking for it....I didn't have have the money at the time so I scraped up all my pennies and made it happen, didn't want to let that deal go
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
15x3.5 up front with your standard 165R Metric VW tires for skinnies
15x10 with 7.5 backspacing ET streets 17psi, 26x11.5x15's they work great, but I need to get ET drags back there.
Here is pics of the LM-1 "mounted"
Underneath, WBO2 in the rear O2 sensor bung....I don't have rear O2's anymore so its the perfect place....
![](http://home.comcast.net/~jsbird1998/wb.jpg)
Here is where I have it routed too, nice and clean cut a slit in the rubber grommet and the wire went right up to....
![](http://home.comcast.net/~jsbird1998/wb2.jpg)
Here..... no cutting of the carpet
![](http://home.comcast.net/~jsbird1998/wb3.jpg)
Power comes from the lighter and the wb wire routes by the pass seat
![](http://home.comcast.net/~jsbird1998/wb4.jpg)
Final resting place and operating
![](http://home.comcast.net/~jsbird1998/wb5.jpg)
You can also run this through the laptop, with the Logworks program that comes with it. I have been saving logs to the LM-1 and then bring it inside to the laptop and DL'ing the info to it and going over the logs in the house. They have a/f gauge like the dynojet one but you have to buy it extra
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
J
#34
Yep, ET's street for the daily driving, but if I have to make a long trip the old 5 stars go back on
But Streets and skinnies all the time...
Black LS1 I agree 10000000% percent![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Another vote for GoodYear Gatorbacks........ Im going to order that belt from Autozone...i have a gift card
Kyle
#36
Summit racing carries Gatorbacks. I'll give one a try since you guys seem to like em. Price is right at only $21.99 for a 48.5" 8 rib.
this is the link for a gatorback for a 2.5" pullied Vortech.
http://store.summitracing.com/esearc...umber&x=20&y=7
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#37
Cooo
never bothered to look there, here is the link to the 52.5
http://store.summitracing.com/defaul...tt=GTR-4080525
Thanks SJH
They also carry a 53.5 and a 50.5....no 51.5 guys![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
GTR-4080505.....50.5
GTR-4080535.....53.5
GTR-4080525.....52.5
J
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Thanks SJH
J
#38
Cooo
Thanks SJH
Thanks SJH
J
Awsome................... Jer you going to buy one when they get them in??
