Hey Everyone 2001 5.3L Single Ideas
I decided on doing a budget friendly single turbo, with a new intake manifold, Truck needs a new exhaust anyways, so might as well change it up a bit. Also will be installing new LS9 head gaskets and head studs. Might just re ring it, and gasket it also to freshin it up.
My queston is, Ill be at stock compressionish, but Im limited on Octane. All I have is 90 octane as our premium.
Im not set on a HP number, still want to daily it
So what would you guys use for a turbo size?
Injector size?
Cam?
I know its asked alot, but Im hung up on the 90 octane aspect. Thanks guys
Depends on your power goals. But for most, a 7875 turbo is plenty. A good matching set of injectors that will max out around the same time that the 7875 will (700whp comfortably) are the Siemens Deka 80 lb injectors. They are cheap, proven, and injector data is available to be put into the factory PCM.
On 90 octane and stock compression ratio you should be able to do 500whp, but for more than that I would recommend a simple water methanol injection system. That can get you to 600whp+ with pump gas.
As far as the cam and valve springs, go with a smaller ish cam (search for Triple 12 cam - very popular for turbo LS trucks) and PAC 1218 springs.
I also recommend a decent oil pump and LS2 timing chain setup, new LS7 lifters, and LS2 lifter trays.
Your questions are asked daily, so you should be able to find similar answers in many many other threads, as well as other peoples results from similar or near identical builds. The items I just described are arguably some of the most popular budget turbo LS items
