Single BW s366 (Step in)
Old Mar 30, 2017 | 03:01 PM
  #41
SLOW SEDAN's Avatar
Originally Posted by gtistile
This just sounds like bad info... i'm running an S484 on less cubes, with a manual trans... what he's explaining does not happen... period.
here you go, tell me how long that takes to spool up lol
https://youtu.be/_yj7yDnj-u8
And what was that about loss of boost between shifts???
https://youtu.be/9Lzmqwb_FAw
lol I was waiting for that video... I think if you have lag then you have a shitty tuner!
Old Mar 30, 2017 | 05:55 PM
  #42
94LS1B4C's Avatar
what turbo do you have?
Old Mar 30, 2017 | 06:16 PM
  #43
20psiofevil's Avatar
Originally Posted by LJMSJohn
the Sxe is a completely different turbine wheel... you cant sit there and say they are the same and then start describing the differences between them.
Same size 80/73mm turbine.
Old Mar 30, 2017 | 06:23 PM
  #44
Project GatTagO's Avatar
I am just a dumb dumb and I am trying to learn from people that know better than me...
So...if anyone can shed some light to the differences, I would appreciate it.
Andrew
Old Mar 30, 2017 | 07:52 PM
  #45
SLOW SEDAN's Avatar
Really?
Old Mar 30, 2017 | 08:42 PM
  #46
94LS1B4C's Avatar
Really?
no I got it
Old Mar 31, 2017 | 06:09 PM
  #47
Andrew
These show old cast vs the new sxe. You can see the sxe has more of a cupped shape to promote quicker spool.
Attached Thumbnails Single BW s366 (Step in)-borgwarner-s300sx-91-79-turbo-content-6.jpg   Single BW s366 (Step in)-s300turbinewheel.jpg
Old Nov 3, 2018 | 12:56 PM
  #48
Ford_Assassin's Avatar
Originally Posted by kbracing96
I've got one on my C10 but it's non-intercooled blow through carb. Running about 9lbs right now. It's a blast to drive!! I just about got my dyno setup so should have some numbers in a couple weeks.
Attachment 587570
Attachment 587571
5.3 or 6.0?
What cam specs?
Old Nov 3, 2018 | 01:31 PM
  #49
kbracing96's Avatar
Originally Posted by Ford_Assassin
5.3 or 6.0?
What cam specs?
It was a 5.3 with a 215/215 112 cam. Made 580 on 17lbs with the non-intercooled carb and 15lbs intercooled. Was a bit lower than I expected but that motor never performed like I expected it too with boost for some reason. Put a LSA blower on it and made 510 on 15lbs, then I pulled everything off it and NA it made 335 so I don't know what it's deal was, lol. I pulled it out and the truck now has a NA 6.0 with summit stage 2 boost cam and is making 380 NA with A Holley Dominator FI. I've got a pair of BW s359/68's going on it this winter.
Old Nov 3, 2018 | 03:06 PM
  #50
My '74 K5 2wd has a VS 7875 on my LQ4/6.0 with a 235/231 630/605 114 Tick cam. Never dyno it, but it runs good (7 psi). It's weird that it doesn't really have any turbo whistle like all my S475 did (even before they are making boost) that was on it before.
I considered going to a S366 since it's not a max effort setup.
Old Nov 6, 2018 | 12:20 AM
  #51
gnx7's Avatar
Spending over an hr on the phone with a tech from Borg, pointed me in the S300SX-E dirrection. He explained that a 346, with the S475 with a manual transmission would be a dog on the bottom end and won't come into boost until late, then loosing all boost during shifts.
A Precision T4 GTS76 Gen1 (1200hp rating) spools well on a 6.2 liter LS setup (Mast LS3 380cfm heads with stock LS3 intake) running a T56 Magnum and 3.31 gears (26" tall tire). Shifting a bit over 7000rpm it comes back on strong every shift albeit with some spool delay. Going to a bigger 88mm T4 (1450hp rating) on the same engine resulted in a little slower spool time... but the top end pull is no comparison as the 88 truly outshines it overall still with a T56 Magnum manual trans. Both are ball bearing and billet compressor wheel turbos ($2K+ each new).
Crossover is 2.25" piping..... dual 38mm Tial WG's into a single 3.5" downpipe. Decent Treadstone intercooler.
