5.3 turbo build
ZO6 cam Ls7 lifters
317 heads w/pac1218 Springs
Ls9 head gaskets
TBSS intake w/92mm throttle body
80lbs injectors
1 3/4 turbo headers
Opions on a good turbo size ??? This still at "build" stage but it will probably ended up in a gbody car with a 700r4 Trans, maybe like 3.73 gears. A 80% street terror and 20% track....
https://www.full-race.com/store/turb...64-5mm-1.html/
Here is the compressor map, charted to a 5.3L engine with reasonable VE
notice at 15psi of boost, more than I will run for most of the driving I will do, it runs near the edge of the map around 650 horsepower, which is more than I will ever want from the setup. So in essence the turbo is still a "bit too large". Why anybody would install anything larger *cough* is beyond me, it seems like an epidemic around here.
I put the majority of my build funds into the trans/converter (4l80e / 9.5" yank 2800)which seems like the soft spot in 500+rwhp setups.
ZO6 cam Ls7 lifters
Ls9 head gaskets
80lbs injectors
1 3/4 turbo headers
Now if he comes back and says it only has to last 12,000 miles or 5,000 miles that is another thing all together. So this is what we really need to know: how long does it have to last? On week? We can make 1000rwhp for a week I bet.
Gen III 5.3, 125K miles, all stock except valvetrain
LS6/Z06 cam, LS6 springs
60lb injectors
LS3 exh manifolds
s475 t4 83mm turbine
th400/cheapish converter/3.27
Ran 135mph in a ~3400 Mustang at 16psi. For the money it was great and responsive. Probably could do the same with a cheaper/better fitting turbo.
Second, when starting from zero, one should NEVER let the drivetrain dictate what turbo to use. It works the other way around: you setup the engine the way you want it to be used first, THEN you build the drivetrain in harmony. I would never sacrifice low end torque because of a transmission that I was not going to be able to use anyways. That is how the quote above reads: "the turbo makes too much low end torque for the 700R4, which he will not be using anyways, so it is not good to use that turbo". It doesn't make any sense.
ZO6 cam Ls7 lifters
Ls9 head gaskets
80lbs injectors
1 3/4 turbo headers
https://m.ebay.com/itm/92mm-Throttle-body-TPS-IAC-Throttle-Position-Sensor-For-LSX-LS-LS1-LS2-LS7/142214761455?hash=item211ca90bef:g:6NYAAOSwNWxZ7WF 7
