Extreme Cheapskates, Turbo LS edition! Trying to go 9's for $2000
The most expensive single component you'll need to buy will probably be the 58x to 24x convertor box. Or will you pull the crank and put a 24x wheel on it?
edit - sorry missed the last video where it was already running
Whack the shaft down sloppy style and use a couple pieces of angle iron as V blocks band clamped in place to spot weld straight then finish welding it up. Good to go!
#32
hate to admit it but the intercooler in my nova is a stock intercooler from a international 3800 school bus. I cut the inlet/outlet off and moved them to the ends and spool gunned them on 4 years ago. it is a 25 by 13 by 3" core . it works great. and I only see about a 1/2 lb pressure drop from turbo outlet to throtlebody. .
I ran a 350th with a $25 shift kit for the first year in the car ran 10.50s at 10# boost with it. it never failed but at that time I was running all stock 10 bolt axle and driveshaft and 350th so I never turned it up. good luck.
#40
I have a set of 10 year old 28x9 et drags that have a few hits left on them that I got for free, this is the time of year everyone puts on a fresh set around here so I'm hoping something comes up for extremely cheap. Worst case I've had people offer to lend me slicks but I'm trying to stay out of the freebies with this build to keep it more realistic.
