Stroked 5.3
Where is the weak link on the LS when it comes to high high revs? The oiling system mostly? I am speaking to built bottom ends, not SBE.
The valvetrain can be resolved using rather conventional methods...
I think a lot of the stability/reliability has to do with the cam’s lobe profile. Nice gentle ramp rates and moderate lift seem to make high RPM possible with very little in the way of aftermarket parts. A stable/reliable 7k redline seems easily attainable these days with VERY little investment in an LS. Aftermarket cam companies usually had super high ramp rate snappy lobes for NA applications. Seems they are only now learning (in the past few years anyway) That a lazy stable lobe goes a long way with a turbo engine.
Capazzi is a great example. He took a literally stock 5.3 short block. Installed a cam, springs, push rods, and spun past 8k RPM for a season. All on factory lifters/rockers/heads making lots of power. Capazzi even tore down the engine for us after a season of bouncing off the 8300rpm rev limiter and dipping into the 7’s. Engine/valvetrain looked great. Pretty hard to believe… but it happened. I don’t see how increasing displacement is easier than the “capazzi method”.
Adding displacement isn’t really easier on anything. I think people just use better parts when they go that route. Larger pistons are heavier. More stroke adds additional side loads and bumps up the mean piston speed. A 4” crank also hangs the piston out of the bottom of the block which leads to rocking and increases wear/tear a ton.
Cam lift profiles are extremely important and your right...off the shelf cams are very aggressive. Because of this I designed my own lift profiles on my cam, which took a very long time. I made sure the acceleration and jerk profiles were reasonable and there were no undesirable changes at the start and close of lift, as well as on the nose. Ramp rate can be slow, and you can still screw these up and cause all kinds of undesirable valvetrain dynamics. A lot of the off the shelf cams with light ramp rates do not have this figured out.
Additionally, the rocker ratio is not constant...it is always changing. I took a bunch of measurements of this based on a couple valve heights and plotted it. The rocker ratios were integrated into my calculations to further refine the cam lobe profile. This cam should make the power and be EXTREMELY stable.
I know this has been linked to death.. but here it is again!
http://www.hotrod.com/articles/20-ls...ifolds-tested/
I've heard of guys with 408s going with 75k miles with no problems... and the 6.0 blocks have one of the shortest sleeves in the LS family.
You had your last engine built by HKE right?
http://www.jepistons.com/TechCorner/PistonCoatings.aspx
