Stroked 5.3
Old Apr 7, 2017 | 12:47 PM
oscs's Avatar
Default Stroked 5.3
Anyone here have an opinion on stroking these newer 5.3's and boosting them? I'm talking about stock bore size and a 4" crank so basically 350ci. Ive got some pretty radical plans for this LH6 motor (1/2" studs, Athena gaskets etc.) just curious to hear from anyone who has stroked one out and boosted the hell out of it.
Old Apr 7, 2017 | 01:48 PM
svslow's Avatar
Not sure if I have seen one actually running. Got a buddy who has all the parts ready to put one together though.
Old Apr 10, 2017 | 07:53 AM
oscs's Avatar
No one is running the factory 5.3 bore with a 4" crank? Anyone care to chime in on the longer sleeves found in the aluminum 5.3 vs iron blocks?
Old Apr 10, 2017 | 08:16 AM
408GT's Avatar
The guys that got the "sbe" 5.3 in the 4's ended up making a 363 out of their 5.3 with a 3.8 bore and 4" stroke.
http://www.yellowbullet.com/forum/sh...+stock&page=35
Old Apr 10, 2017 | 11:34 AM
oscs's Avatar
Great thread minus the bickering in the beginning. He mentioned some oiling modifications that the engine builder made to achieve a better "film" over the thrust bearing. He also made mention of a "common" oiling modification they did to the mains? I'd love to hear more about that but it doesn't seem like he's fully aware of what was done to it.
Old Apr 10, 2017 | 12:13 PM
408GT's Avatar
That's why I put SBE in parenthesis. That guy BONESAW wouldn't let it go...
He either doesn't know, or doesn't want to say on the oil mods.
Old Apr 10, 2017 | 01:16 PM
blackonblacksls's Avatar
The oiling mods to the thrust are just slits in the bearings if it's the same as the ones everyone else always talks about.
I had a little motor I'm doing the same with. Gen4 alum block, dry sump 4in crank, 6.098 rods, and a 3.8 bore custom piston and big pin.
I'm worried about 1/2in studs on the alum block. So haven't decided on that yet
Old Apr 10, 2017 | 02:09 PM
oscs's Avatar
I wouldn't be. Tons of people are running the 1-2" studs.
 Michael S. Palmer
Old Apr 10, 2017 | 02:10 PM
oscs's Avatar
I'm assuming this is to bleed off pressure while it's on the brake?
Old Apr 10, 2017 | 02:22 PM
KCS's Avatar
KCS
Moderator
I've seen where guys drilled through the thrust flange of the bearing into the main saddle to intersect the oil passage to the mains. The intent is to directly supply oil to the thrust, but all the oil going to the #3 bearing comes out the sides and into the thrust face anyways. Not sure how much it really helps.
Old Apr 10, 2017 | 03:00 PM
oscs's Avatar
I'm having a hard time picturing this.
Old Apr 10, 2017 | 03:23 PM
Forcefed86's Avatar
What is the real benefit of stroking it anyway? ()
Most performance turbo engines destroke. Just an observation, not trying to start $hit. After seeing how well capazzi is doing revving the factory stroke SBE 5.3 to 8300... I'd think that woudl be more beneficial. Would be cool to see either way.
Old Apr 10, 2017 | 05:57 PM
KCS's Avatar
KCS
Moderator
The drilled hole intersects the oil valley that supplies oil to the main bearing.
Old Apr 10, 2017 | 07:15 PM
oscs's Avatar
I'm cool either way honestly. Just looking for healthy discussion on the best way to make the most amount of power. Being a 26" tire guy on a glide I like the idea of extra RPM.
Old Apr 10, 2017 | 07:16 PM
oscs's Avatar
Wouldn't that just bleed off pressure?
Old Apr 10, 2017 | 07:19 PM
Forcefed86's Avatar
I'd think with relatively small cubes you'd get the most efficiency and power using light weight small parts at higher RPM. Lose converter and pump tons of power to it well over 5k.
Old Apr 10, 2017 | 07:43 PM
KCS's Avatar
KCS
Moderator
Well yeah, but I think the intent is to supply that pressure directly to the thrust face rather than just relying on what comes out the sides of the bearing. I don't really know if it works or not; its just something I've seen others try out.
Old Apr 10, 2017 | 08:28 PM
oscs's Avatar
I appreciate the pictures
Old Apr 10, 2017 | 09:43 PM
tblentrprz's Avatar
I'd like to better understand what guys are doing to produce stable valve train at 8000+. Surely easier to do with smaller parts on a small bore compared to 4"+. RPM is the equalizer to cubic inch. If my math is correct, a 5.3 at 8050 is flowing the same air as a 400" at 6500.
Old Apr 11, 2017 | 07:16 AM
roastin240's Avatar
When you start moving up beyond 7K rpm, the required attention to detail increases exponentially. Hard to utilize lightweight parts in such a harsh environment that sees very high temperature and pressures. Its always easier to increase displacement and keep the RPM's down...That being said, document whatever it takes to build a reliable 1000hp+ high revving 7K RPM monster. I would much rather have a high revving LS in my opinion.
Where is the weak link on the LS when it comes to high high revs? The oiling system mostly? I am speaking to built bottom ends, not SBE.
The valvetrain can be resolved using rather conventional methods...
