What pipe material/thickness for a rear turbo?
Old Apr 13, 2017 | 05:12 PM
Brian Coles's Avatar
Default What pipe material/thickness for a rear turbo?
Plan is to go back to coated headers and wrap the pipe to the turbo. Also going to 2.5 in diameter to keep heat/flow back to turbo. What economical pipe material/thickness should I use?
Old Apr 13, 2017 | 09:02 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I hope by headers you mean stock manifolds, because individual tube headers will make your heat loss problems going to the turbo far worse. The heat loss in a rear mount system is an unavoidable issue that hurts power and spool time, so do everything possible to minimize it. As for hotside pipe material, I would use whatever cheap exhaust pipe is available, but then use the best heat wrap material I could find all the way back. I can tell you from personal experience that the results will still be far inferior to a properly built front mount setup, but I understand that you only asked for advice on how to do the rear-mount.
Old Apr 14, 2017 | 12:14 PM
RooRnZ28's Avatar
Most economical will be aluminized pipe, best would be stainless but that will be $$$ and heavy.
Check out this older thread of mine, might give you more insight on what works for a rear mount.
https://ls1tech.com/forums/dynamomet...y-sts-kit.html
Old Apr 15, 2017 | 11:03 PM
rpturbo's Avatar
What is this going on? I would consider 2.25" pipe also.
Old Apr 18, 2017 | 12:20 AM
Yes going w/ coated stock manifolds. Saw other rear turbo posts that 2.5 will work just fine and spool quickly. Will y pipe w/ high flow cats help or hurt?
Old May 1, 2017 | 09:01 PM
LS1 pwrd NOVA's Avatar
Any updates or info on this ?
Old May 1, 2017 | 09:05 PM
gametech's Avatar
High flow cats will hurt quite a bit when pieces of them go through the hot side of your turbo. It is not a matter of if, but when this happens. This is another downside of rear mount setups. If you make them emissions friendly they will eventually self destruct.
