gained 40 hp/ 25 tq @ 8psi from modifying my STS kit
previous dyno #s: (8psi)
![](http://i145.photobucket.com/albums/r201/mackzero/dyno.jpg)
new #s: low boost (5psi) and high boost (8psi)
![](http://i145.photobucket.com/albums/r201/mackzero/june2009dyno.jpg)
changes:
stock exhaust manifolds (removed LT headers)
bassani offroad y-pipe
deleted sts over axle intake pipe
deleted sts pcv system
re-did intercooler piping to go over the radiator
installed performabuilt level 3 tranny/3000 stall
installed 9" rear w/ 3.25 gears (from stock 10 bolt, 2.73s)
added magnafuel pressure regulator at the fuel rails
changes:
yep the stock manis made a difference alright, along with changing the sts intake piping... I was thinking that I would lose power thru the stalled a4 and new 9" rear end, but I was happy to gain some!
I need to wash this bish so I'll take some pics of the changes this weekend and post them up. There are some already on my CarDomain site, but none of the engine bay yet.
Nice Camaro!!!! Good looking car nice work
You only lose boost on supercharged engines when you swap the stock man's for the lt's, because the stockers slow the flow soo much that they make the burned air hang around causing more boost. Now with turbo cars... They love air moving in and out as fast as possible because that turbo will spool up more with the increase of airflow. So adding heads or cams or lt's won't hurt boost or power just add more!!! So those lt's helped out a lottt, increasing airflow in and out adds more power! just my .02
It picked up with the manifolds because the manifolds hold heat better and heat is whats spins the exhaust turbine.
Thats why in nuetral a car wont build boost if you hold it at a steady 3,000 rpm, but at that same 3,000 rpm going up a hill, it will, because load creates heat.
Nice work tweaking your setup!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I have had the kit on since December of 2006 and have put roughly 15000 miles on it. For now, I am happy with it but the base kit has needed numerous changes for it to perform. It has taken me the past 2 years to fix all the little things, but the car is much more responsive now and a blast to drive.
The only thing i every worry about is the oil return pump going out on me... When I get the chance i plan on replacing the sts pump with something better and more reliable
No, he took the LT's off.
Nice work tweaking your setup!![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
yes, it used to be LOW. That last pic was taken the day I drove it home from the mechanic after the kit was installed. There was only like 2" of ground clearance.... It has been fixed since then and tucks up much higher now. Nothing even comes close to hitting it
