s476r slow to spool or not.
one of the hot sides I built is on my buddys Camaro with 2 1/2 to a single 2 1/2 looks exactly like the truck setup and has ran 9.40s on a 5.3 at 3550 raceweight with a on3 78/75 turbo @ 20 psi boost. I'm not seeing the big restriction at that power level yet. and i'll tell you the truck 2 1/4 setup pulls very good up stairs we have ran it to 7000 rpm on the ls2 370" engine and ljms stage 2 and it keeps pulling up there. thanks.
A 370 feeding a bigger turbine needs more volume to spin the turbine while the car is at the starting line......not a merge pipe the same size as the primaries. If you want 2.125" or 2.25" then they need to stay divided all the way to the turbine wheel.
Also the smaller pipes increased velocity will have a greater impact spool speed than additional volume. Question is if the piping is small enough to be a choke point at his 370s current power level. Which I doubt.
my idea with single 2 .5 or 2.25 pipe is to gain velocity entering the turbo. I have seen no evidence showing the pipe is to small. in a week or so we will do some track testing and I will let you know how it works. I know the 2.5 single pipe works great . thanks.
But, in practice I cant see how it wouldn't be a benefit.
the motor was 500 RPM quicker to get to 105 kpa, 5 psi , 10 psi.
The hotside was the only change.
Thank you sir! Not sure how hard that set up was pushed but did you see any differences up top?
