s476r slow to spool or not.
this has been an issue sence we have had it on 2 different engines and complete hot side changes.
here is the setup as it sits
370" new engine flat top diamond pistons
ls9 gaskets fresh stock 317 heads 10.5 compression.
ljms stage 2 cam . degreed to verify cam timing.
truck manifold forward and down manifolds 2 1/4 piping nice and short
no leaks borg etr ho 476r 76/92 1.25 t4 open 4" downpipe.
no wastegate leak or any leak of any kind.
here is what we get.
with a 5 second wot trans break hit with the 2 step at 3900 rpm the engine flashes to about 2800 rpm converter flash then builds boost slowly up to the 3900 rpm setting . and will make 4.7 psi boost in 5 seconds.
lowered the 2 step to 3000 rpm and it comes up and hits the 2step fast but will only build 1.4 psi boost in 5 seconds.
the afr is in the 13.5 area before the launch control hits.
my question is this right seems damn slow to me . my cast 80/83 on my nova is a little slow but not like this 76/92.
we have ran it on 2 different engines 2 different hot sides and 6 converters. and if the converter is tight enuff to hold full boost it spools like this. thanks in advance.
when getting to the launch control rpm of 3900 it takes 4.7 seconds to build boost from 0 to 4.6 psi with no 2 step just wot and trans break at 12.6 afr on e85 and 26 degrees timing while building. . . I have triple checked everything and there are no exaust or boost leaks. this seems really slow for a 370" 10.5 to 1 engine.
it makes power it ran 10.32 last year at 137 mph at about 4300 to 4400 lbs race weight it is a 2003 rcsb Silverado. leaving at 5 psi or so on the break but still does not get to full boost until 2nd gear or 100 ft out or so.( old hot side and 6.0 with 218 jarrett cam. )
Best spool I could get before I messed with the tune alot.
After trying a bunch of strategies of when to pull timing and how quickly and how much fuel to add. I cut my spool time in half.
interesting think is we checked last years logs and the old sbe 6.0 with 9.5 to 1 compression and stock48 218 cam was a little stronger out of boost and was getting almost 3000 rpm converter flash.so even though the new engine is 10.5 to 1 compression the ljms stage 2 gives up a little power down low all things being equal.
3rd gear spool
) if that is what your saying I will build one and try that out.
Have you done a back to back on something to show this? I asked about this a while back, and we met with a bunch on internet scientist saying that "it work work right" since its basically impossible to "pair" the cylinders "correctly".
But, in practice I cant see how it wouldn't be a benefit.
Back when I had an undivided Garrett T6 turbo, this is what my hotside looked like. It was 2.5" pipe. Spooled fine. Now with the S480, divided turbo, I have remade the hotside to be true 2.5" divided. Still spools fine.
