4.00 stroke, 3.78 bore?
How dumb would it be to take a 4.8 engine, hone the cylinders, re-ring it and put 5.3 rods & a 4" crank under it?
The goal is not horsepower but off-idle torque.
I think this recipe gets to ~360 CI and, with the factory cam (or an RV of some variety) it should make more off-idle torque than a 6.0 swap with the benefit of new rings & bearings, too.
I'm confused (obviously). I'd thought the stroker engines were using a 6.125" rod, common to the LS1 and 5.3? Where did I go wrong, and which rod would I want?
EDIT: Pistons.
Do the 4.8 flat-tops have a different wrist pin height than the 5.3's?
undersquare motors make better off throttle torque
they are also the most efficient.
since you cant put a ******* 5" crank in the LS that pretty well means the only path to undersquare is s 4" crank under small bores...
im essentially trying to build exactly the same thing as this guy. 5.3 truck block, sawed off ls7 crank, ls7 rods, custom pistons, shaved 862 heads with a 2.0 valve shoved in there with ls7 lifters, ls6 springs, brass trunions, and a BTR cam...
how is this any dumber than a 383 besides being more so what a 383 is.
yall dont think 5.9l is enough when everybody with a bone stock junkyard LQ4 thinks putting a cam in it equals racecar or whatever the big bore cult is on about???
“Its final iteration was launched in 2010 with the Mulsanne, Bentley's top offering. Rated at 507 horsepower and 752 lb-ft of torque, it delivered the "effortless wave of torque for which Bentley is renowned"”
Its low-revving, ultra-silent operation felt like nothing else on the road, its characteristics perhaps closer to a diesel than a gasoline engine but without any of the rumble.
Someone had a small bore rectangular port head if I remember right.
