Forge my Ls1 or build 6.0
ARP main studs
Wiseco Forged -3.2cc Dished Pistons for 3.905" Bore, 3.622" Stroke, Part Number K398X3905, includes file fit GFX rings and .927" diameter pins. 1.304" compression height for 6.125" long rods.
Callies Compstar H-Beam Rods; 6.125" LT, 2.100" Rod Journal, .927" Pin
Between parts and labor it would be around $3,500. TSP has a Gen 3- 370 iron short block right around $4,000. Could I bolt everything from the Ls1 to that and be done? Are all the sensors ect the same?
Turbo is a master power T-70 with a .96 ar housing
C6 manifolds flipped upside down
Speed in Tu1 turbo cam
Pac 1218 Springs/pushrod/retainer kit
