Anyone running the Vortech LS Swap kit?
https://vortechsuperchargers.com/col...nt=21975316935
Looks to have decent belt width, a bit tight around the water pump inlet in terms of belt clearance, but otherwise ok.
I would like to see a good spring tensioner on it though if it was ever to make any decent power, but of course that would vary massively for each build.
I agree, not going to get a lot of boost with a manual belt tensioner. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Not saying a strong spring loaded setup wouldn't be better to account for belt stretch, but for the time being I have been running my procharger setup up to 25psi with a manual tensioner and had no issues. Then again, I am running a 12rib belt.
A strong spring tensioner can maintain tension on the belt even when it has stretched under load because it always tracks the belt
Although the kit above is a base kit so not a big power item. So it would probably be fine with a manual tensioner.
Procharger with a higher internal stepup ratio generally use larger pulleys, so more belt wrap so perhaps less likely for belts to slip.
But a fixed tensioner is not the best solution...ever
There are several videos online to give you an idea. Check out how much this tensioner is moving and how much the belt is stretching. So how much would you need to preload a manual tensioner setup to try and compensate for that ? You'd be pulling the **** out of everything, damaging bearings etc
The only info i have found is a CarCraft write up on their Orange Peel Chevelle.
This is not my 1st choice (i want an A&A bracket with a Vortech) but a good friend of mine has offered his new kit to me for a great price. I am considering it.
didn't know what you remembered that night at the track with a beer in hand.
Great it all depends what u want street car or run a really great# at the track
Becuase a centrifical is deff much better just my thinking
