Transferring internals to another block, stock ring gaps huge.
Old May 13, 2017 | 01:06 PM
Cwarta's Avatar
Default Transferring internals to another block, stock ring gaps huge.
I'm transferring the gen 4 24x internals I have from and 05 iron 5.3 block into a spare l33 block I have sitting here for my turbo iroc. Plan is 15-20# on e85. I put the rings in the block and used the caliper to set depth so it was even.
Top ring has .040 gap and bottom has .035, untouched. Came out of a perfectly fine running 05 Chevy. Since I'm transferring from iron to aluminum I thought maybe there was a difference in the bore slightly to make up for expansion rate differences, so I rechecked it in the iron block and its identical. Anyone ever seen this before???
Old May 13, 2017 | 01:50 PM
truckdoug's Avatar
those probably won't butt
Old May 13, 2017 | 03:10 PM
stevieturbo's Avatar
Butt....they'll still work perfectly fine.
Although most will prefer a larger 2nd gap than top, so open up the 2nd a bit.
Old May 13, 2017 | 06:05 PM
forcd ind's Avatar
I would ck all rings, mark the cyls they will go in
Old May 13, 2017 | 09:24 PM
Cwarta's Avatar
I matched the bottom to the top. All rods and pistons/bearings rings stayed with their corresponding journal/cylinder. Everything was in excellent shape.
Old May 13, 2017 | 10:45 PM
Nathaninwa's Avatar
What comes to mind if the gaps opened up from the other block, is piston to wall clearance. Don't want a piston slapping block when you fire it up
Old May 14, 2017 | 01:07 AM
Cwarta's Avatar
I checked that, ring gap is identicle in either block. That was my first thought as well.
Old May 15, 2017 | 07:58 AM
KCS's Avatar
KCS
Moderator
I've seen the same with a 4.8L I took apart. Gaps were huge like that and it was a 100% stock engine. It had a lot of sludge so I don't think it was well maintained.
Old May 15, 2017 | 10:38 AM
Cwarta's Avatar
This motor was also sludgy. Spent a lot of time degreasing and cleaning.
She's up and running now. Just the slightest haze out of the catch can. See what she does.
Zero trouble building boost on the brake. Brought it up to 0 and then leaned into it.
Old May 15, 2017 | 10:55 AM
newschool72's Avatar
https://youtu.be/ZR1n-PM3AEE
The blow by might be partly from the rings not seating in to the new block yet. How much have you run the new setup so far? As far as the ring gaps go, I would rather have too wide a gap than not enough !
Old May 15, 2017 | 11:17 AM
Cwarta's Avatar
I drove it to work today, so far that's it! When I parked she had a slight haze coming out of the catch can breather. I agree, little haze won't bother me any. Another broke piston will
Old May 15, 2017 | 01:07 PM
truckdoug's Avatar
yeah my newest motor has reused rings in a dingleberry honed bore and they smoked like fresh rings until I had some decent miles of loaded cruising on them.
hey are you on pump + meth or corn?
i'm trying to figure out how much to spray and when. we have the same turbo and spool about the same speed.
Old May 15, 2017 | 01:18 PM
Cwarta's Avatar
I'm on corn, I just hooked up my pre compressor meth injection last night. Excited to try it oit
Old May 15, 2017 | 02:01 PM
Are you running an inner cooler ?
Old May 15, 2017 | 02:36 PM
Cwarta's Avatar
No sir, just going to run meth. Small nozzle pre compressor and a m15 nozzle after compressor if needed.
Old May 15, 2017 | 02:37 PM
Cwarta's Avatar
Old May 15, 2017 | 02:45 PM
Gotta love the simple plumbing when theres no innercooler ! That was my first plan. No cooler and just water/meth. I chickened out before I even took a test drive. E85 is too hard to get where I am, so 93 is the rule. I took the meth off and stuck a 29x12x4 innercooler up front. Still have the meth kit though. If I can make 12 lbs on my setup and keep IACs down on just the cooler, I will sell the meth kit. If not, I recon it will go back on.
Old May 15, 2017 | 02:48 PM
jrtoffroad's Avatar
As long as you have a really good breather setup I'm sure she'll run great. Should be able to take some huge boost without ring problems!!
Question though, why would you re-use the rings? Is this a super budget build?
Old May 15, 2017 | 03:02 PM
roastin240's Avatar
Ya I wouldnt re-use rings when swapping blocks. I would have bought cheap OEM replacement Mahle rings off Amazon for $40, threw a dingle ball hone job on the cylinders and set the ring gaps where I wanted them. Unless you had a time crunch and an event to get the car to, I would have spent the extra day of work to do it.
Old May 15, 2017 | 03:25 PM
He seems to be a Denmah disciple . With the reuse of parts Ive seen from him (Denmah) on his turbo budget builds successfully, I don't question anything about the factory parts being reused anymore, LOL. Runum !
