04 silverado 2500hd vs7875 work truck
#61
If I rotate it more, the an threaded part of the fitting hits the t4 flange on the housing. A straight flange may fit, but looks like it will be so close the compressor housing that I wouldn't be able to get the hose fitting on. A straight hose barb fitting would probably work.
#63
Ah, i see what you mean now.....
it's worth it to try to get it straight and use a hose that's as big as possible if you can.
I think I used a straight turbo fitting......
I'm thinking back to mine and I remember I had to attach my AN fitting to the turbo fitting first, in a vise. I was then able to tighten it just right to align the hex on the AN side so that it would fit between there. I used socket head cap screws to attach the turbo fitting (with AN fitting and hose already attached) to the housing... That way I could get up in there with a ball nose Allen wrench.
Would that work on yours?
#64
#69
I made some intercooler pipes out of a box of scrap a friend was going to scrap. The pipe going into the throttle body is a 90 and then straight down about 14" into a silicone coupler. I am paying to have the welding done and I figured I should weld in two 1/8 npt bungs for meth nozzles should I decide I need them in the future. Does anyone have any suggestions for the placement of meth nozzles, ait sensor and bov on this pipe???
I also got the trans cooler mounted under the bed where the spare tire was with a fan, and the oil pan removed, tapped for the drain, and reinstalled.
#72
I used to have my IAT in the intake, would peg the sensor 38F every time meth would spray. Only real positive of this is knowing that your meth is working. I relocated to post intercooler as I was having problems with it being too cold (68F pre-TB) and the meth would not flash off, causing many melted cylinder heads on my turbo 6.
#73
#75
Picking up a set of remflex gaskets for the warped manifold. I belt sanded the warped wastegate flange flat, but that didn't do anything for the recess, so probably going to have to get that fixed when it leaks.
#77
Found a local shop to surface the manifold while I wait. Also decided to cut off the warped wastegate flange and get a new one welded on. I have an appointment tomorrow night to get it welded.
Also found a russell fitting 1/2 npt to -10 that should be long enough to replace the copper.
#80
Thanks!
I had an m14x1.5 bung welded for the zr1 (12614717) iat sensor. I didn't realize that the calibrations are so different between the 2. I did ask in the in the tuning section, but no replies. Does anybody know the data for this to make it work on my p59? Otherwise, I can drill it out and tap to 3/8 npt and use 25036751 which should be the same calibration as what is in there now.
