Timing for pump 93 in boost
Old May 24, 2017 | 04:41 AM
Nitroused383's Avatar
Originally Posted by tblentrprz
383, Care to share finding MBT at various rpms and loads? Dyno? Street tuning? Assume the approach is not different using 93, E85, C16?
You need a load bearing dyno with Eddy current brake to find mbt at part throttle. Atleast that is the only way I'm aware of and it takes a decent amount of time to dial it all in. You find the minimum timing that makes the most torque in ever cell you are tuning with real time tuning controls.
