random lean spot in boost
Old May 26, 2017 | 09:13 PM
Dylanplace's Avatar
Default random lean spot in boost
so this truck has had all kinds of issues along the way that you guys have saved my *** on. ive got the truck up and running with a 4.8 and the setup off of my 6.0. so it drives good still a little rich in boost but anyways the truck only does this from a dead stop ans nailing the throttle it will pull hard to 4000 then die right off like no fuel at all and then come back. its really scary and it does it everytime. makes trying to get my timing correct impossible i have a log and the current tune to post. i had this issue once before and someone helped me fix it but i cant remember what it was
blue truck lean hicup.hpt
blue truck lean 4000rpm.hpl
Old May 26, 2017 | 10:49 PM
truckdoug's Avatar
so just some things that pop out to me
it looks like you're commanding 12.25 afr and all PE cells. BE cells are at .8 thats no big as it defaults to the richest of the two.
but i would set those cells in the lower rpms a little leaner. it makes a smoother VE table
then the PE vs TPS cold enable (hot is disabled, good) is on a curve. I made mine all 50% at the behest of ronssnova and it's a lot easier to predict where the power is gonna be with my foot
Old May 26, 2017 | 11:49 PM
truckdoug's Avatar
are you editing your VE with an error % histogram?
i made a video how to set it up after ron showed me how.
Old May 27, 2017 | 08:43 AM
truckdoug's Avatar
oh and before I forget your IATs seem really high for just cruising and squealing the tires
you have an intercooler? spraying water/meth?
