New PB sbe 6.0 stock 80e 76/75 9.58@141
Finally got back to the track to try some testing on pulling timing to add boost and it turned out great! This was launching on 7-8 psi and 16-17 psi through the run. Ended up running lil lean 12.3-12.5 through run but I said screw it ha. It must of gained power cause my best mph before was 138 and now it ran 141 with out changing anything in the tuneup. Lean is mean that's for sure. Added some fuel and it ran 12.0 and only ran 139. Thinking of trying a different wideband to make sure it's accurate. This was on pump ethanol testing 88%.
