I need options on cam specs from some experts
Thanks in advance
You've put together some fine pieces. I recommend you call and speak to a real cam expert. Straub Tech, CaMotion, there are a few others I can't think of at the moment. Maybe someone else here can name a few others.
Anyway, a competent cam designer will take all your desires and parameters into account and make something that specifically suits your build and goals.
If they don't ask for your head flow data, call someone else.
There not always right but entertaining nonetheless
https://www.liljohnsmotorsports.com/
Anyway, it appears those heads, on that specific engine, would be best suited to, and capable of supporting, a peak RPM of just over 8000! Not street cam territory. So, IMO, any street friendly cam you use will be a detriment to what the existing parts combination is calling for.
Now, that's just my opinion and doesn't mean much. Because, it's what you have... Unless you plan to get a smaller port head that's better suited to the application and RPM range you're likely to utilize in a street driven car. Which I doubt is something you'll consider doing, but who knows?
This is a primary case where a competent cam designer can make the most out of your existing combination for your intended use. He'll be able to maximize the valve timing events and ramp rates to account for, and take advantage of, the (reduced) port velocity.
If you just want an off the shelf option, they're all going to be short of stellar and ultimately a compromise... Not a bad thing really. It opens the door to choose pretty much any cam you want. Just pick one that operates in the rpm region you expect to use. Something in the 230-240º intake duration neighborhood may, perhaps be a good balance, giving you a taste of what the heads are capable of, while still being streetable if your gearing isn't too tall.
Anyway, my $0.02. Does any of it seem off to any of you other guys?
Had a lot more in it , so with better tech and Twins should be nasty
He's gonna need pretty much every detail about the build except for maybe the brand of bearings and bolts you used. It's tedious to provide all of it, but time well spent.
In any case, good luck with the build.
1st. selecting the proper events to make the motor work like it should.
2nd. Getting the proper lobes to keep the valvetain happy and stable.
The two are not mutually exclusive. There are plenty of guys in this country who are more than capable of getting the proper events needed for the engine, but do not design lobes.
Not that I'm saying anything you don't know.
You don't design lobes, do you?
This is an easier group of people to find. And John and Martin both understand their craft very well. Both also have had lobes made to meet their own criteria.
