Fuel system base pressure - How low is too low?
Anyways, my system consists of twin Bosch 044's, both on an 8an separate feed from a sumped cell, y after pumps to a single then y back out at the back of the rails, pass thru rails and runs to the reg then back home to the tank.
Could I drop my base pressure to say, 30psi (1:1 boost reference) and stretch out my pumps some and that would make the injectors smaller also.
Would that effect spray pattern/atomization?
Hoping to make around 900whp on e85 with twin 044's.
And a few people have mentioned before that 044's arent always happy long term with ethanol fuels.
Honestly I'd bet you could pull a Denmah and run it at 40-50psi base and not even boost reference it. I believe Denmah was around 900whp and 56% DC at 60ish psi of total fuel pressure with the 210's. (assuming his sensors are correct, they do bounce around alot)
i had to move the set screw nearly completely out.
Problem was, the diaphragm stuck there and pressure wouldn't rise with boost.
so something to watch out for
