Turbo Pipe Material ?s.
Thanks.
Cheers!
I know a guy who builds custom headers for folks, he uses very thin Iconal tubing for his best ones.. But I don't live in that $$ range for a car part.. I think he gets north of 5K for a set of open wheel V8 headers.. But they are SOOOO light..
And I agree with others above, aluminum on the hot side isn't a good idea. I have seen some people use aluminum on the turbine outlet with success.
ETA: mandrelbends.com = Columbia River
The kits i was referring to are using mild steel for the hot side....my bad lol. Last edited by 2muchboostNY; Jun 20, 2017 at 05:20 PM.
Still need to source some good affordable V bands.
Thanks.
There are drag cars with aluminum downpipes. Its not that uncommon.
You can get pretty much everything to make a hotside from somewhere like Columbia River. That's where I get everything I use. I've only made 1 hotside out of stainless. Mild steel is easier to deal with and usually a lot lighter.
For V Bands I found modern automotive performance on ebay to be good quality. I replaced some china stuff with theirs when the v band bolts easily stripped. MAP's v bands use a 13mm nut versus 10 for the china stuffs
they get cracks a lot. i eventually replaced it all with mild steel because my truck is used as a truck. for a weekend beater id probably do it again, especially if i did the first foot or two out of stainless.
