Windshield Washer Fluid For Meth
Old Jun 23, 2017 | 02:59 PM
Modchevelle's Avatar
Default Windshield Washer Fluid For Meth
What windshield washer fluid to run in Snow Stage one on a stock 5.3 and 84mm On3 turbo? Where do you get it also?
Old Jun 24, 2017 | 08:03 AM
jasonsnova's Avatar
So far I'm using advanced auto -20° stuff....seems to work
Old Jun 24, 2017 | 10:53 AM
kbracing96's Avatar
I've run -20 in my truck for YEARS. Rumor has it, it's about 30% meth. Getting it depends on where you live and the time of year. If you're in the south, your going to have to look pretty hard to find anything that's not 32+ rated. When I lived in Texas, I couldn't find it very easy so every time I when up to Wyoming to visit friends, I'd swing in Walmart and pick up a couple cases.
Old Jun 24, 2017 | 11:49 AM
truckdoug's Avatar
i buy it at the dollar store. as long as it says -20 it should be good to go. it'll also have warnings about it containing methanol, skull and crossbones pictogram etc..
just stay away from anything that says propylene glycol or ethylene glycol
Old Jun 24, 2017 | 06:12 PM
Thanks for the info
Old Jun 24, 2017 | 11:06 PM
jimmyg's Avatar
I'm using -20 blue ,then putting 3 12 oz bottles of heet , for a 50/50 mix
Old Jun 25, 2017 | 12:44 AM
pdxmotorhead's Avatar
Why not buy methanol? It's cheap at any chem supply house,, or from
most fuel distributors..
Old Jun 25, 2017 | 02:22 AM
Blown06's Avatar
8 Second Truck Club
Does anyone have a data base put together of the meth content of all the different flavors/brands of windshield washer fluid? That would be a cool list.
Old Jun 25, 2017 | 08:26 AM
Nozzle is before BOV about 20" and bov is not in a good spot IMO. I dont want any fires. Here is a old pic when it was in the build stage
Old Jun 25, 2017 | 08:41 AM
jimmyg's Avatar
Closest place to me that sells meth is N E dragway. 5.75 gal. Just need a good container.
Old Jun 25, 2017 | 09:04 AM
old motorhead's Avatar
Guys in the south can get the -20* stuff at motor home dealerships most of the year.
Old Jun 25, 2017 | 11:12 AM
truckdoug's Avatar
a 55 gallon drum of methanol from tarr runs ~200 + barrel fee last I checked. if you know a cheaper source, PM me
Old Jun 25, 2017 | 03:45 PM
A sticky should be made on this subject
Old Jun 25, 2017 | 05:57 PM
JoeNova's Avatar
Restricted User
There are tons of water/meth % vs freezing point charts out there. You can easily use one to determine how much methanol a bottle of washer fluid has based on its freezing point.
Watch out with some of the purple stuff. They often aren't just water/meth. Same goes for bug/tar remover additives.
Old Jun 25, 2017 | 08:46 PM
3 window's Avatar
BOOM! check out the list http://www.thelsxdr.com/methanol-injection-101/
Old Jun 25, 2017 | 09:36 PM
jasonsnova's Avatar
Nice find.....i was thinking about get to g some straight meth at the track and cutting it 50/50 or 2-1 with -20 stuff to keep costs down.
Altho car seems to do well with straight -20
Old Jun 26, 2017 | 06:30 AM
Originally Posted by 3 window
Nice link 3 window...bookmarked
Old Jun 26, 2017 | 08:54 AM
Forcefed86's Avatar
Cheapest by far to mix your own. Pick up a couple gallons of methanol and mix it with distilled water. 50/50 by volume is fine and generally a accepted as non-flammable.
I’ve never been able to find anything other than -20 washer fluid which is around 30%. Most of the higher rated blends also contain glycol or other additives you don’t want. Just google the MSDS of which ever product you are looking to buy. It will list the methanol percent. IF you have more money than time I’ve used the premixed 50/50 from Devilsown. They ship fast and it’s pretty reasonable price wise.
Old Jun 26, 2017 | 01:09 PM
SLOW SEDAN's Avatar
I used to run whatever was on sale, usually under $3 when filling up. As stated avoid the pricier bug remover and rain-x varieties.
No intercooler, 30+ PSI, 3 nozzle AIS (now prometh) kit worked great.
Old Jun 26, 2017 | 01:38 PM
Yep thats where I get it,, I guess since I play more with 100% meth motors than blending,, It just struck me odd since you don't really know what else is in the windshield fluid.. And they don't really have to tell you the full story on it..
Luckily they are not my cars and I don't pay for the fuel..
