Project Nova - The quest for 1000hp VS s480 l33 347
Old 09-21-2017, 05:21 AM
  #161
stevieturbo's Avatar
Those gaps aint big ! And most certainly will not cause any smoke or other problems.
Old 09-21-2017, 09:19 AM
  #162
Cwarta's Avatar
Good! If I followed mahles turbonring gap specs I'd have like .018. Wtf
Old 09-21-2017, 10:26 AM
  #163
MY_2K_Z's Avatar
lol I gapped the **** out of my rings in my ly6. It smokes a little after a pull but I think that's due to inadequate crankcase ventilation which I plan to fix soon.
Old 09-25-2017, 07:40 PM
  #164
Cwarta's Avatar
Tigged my reluctor wheel on today. Hoping to have the engine together tonight.
Old 09-26-2017, 12:38 AM
  #165
Cwarta's Avatar
Longblock is assembled
Old 09-26-2017, 09:25 AM
  #166
Is it not as much a case of tigging the two parts of those 2 piece rings together, than simply tigging one part to the crank ?
Old 09-26-2017, 04:43 PM
  #167
Cwarta's Avatar
The reluctor is 1 piece, it's spot welded to itself from the factory. You just gotta tig it tonthe crank. Don't use any rod, just puddle it front the two parts
Old 09-26-2017, 04:46 PM
  #168
Yes, and it's those spot welds holding the 2 pieces together that can also fail.
Old 09-26-2017, 05:18 PM
  #169
Cwarta's Avatar
Hmm, haven't seen that, only the whole thing come loose.
Old 09-26-2017, 05:49 PM
  #170
It's the reason why some places make a billet 1 piece wheel, the 2 piece design is just crap.
Old 09-26-2017, 08:42 PM
  #171
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
Hehe watch that blood pressure.
I'm planning 28 for both rings.
Old 09-26-2017, 09:36 PM
  #172
Cwarta's Avatar
Happy now? You scared me into taking my engine part again ��
Old 09-27-2017, 05:24 AM
  #173
Better indeed yes.
here is a 1 piece example, just for reference. Although unless pushing 6500, 7k+ most dont have too many issues anyway
https://www.briantooleyracing.com/bi...el-140024.html
Old 09-27-2017, 08:57 AM
  #174
Cwarta's Avatar
Thanks man, hopefully I've done everything I can to help it be reliable
Old 09-27-2017, 08:29 PM
  #175
rkupon1's Avatar
This is probably a silly question, but will/can tack weld(s) throw off the cranks balance? Just curious is all
Build is coming along nicely
Old 09-27-2017, 09:04 PM
  #176
Cwarta's Avatar
Shouldn't, I didn't add any filler rod. I just melted the two components together.
Also it's close to the crank centerline
Old 09-28-2017, 04:21 AM
  #177
rkupon1's Avatar
Got it, that makes sense. Can not wait to see some videos of this nova makn some boost
Old 09-28-2017, 05:16 AM
  #178
The weight of any weld, would probably be less than the weight of any oil hanging around the crank during rotation anyway ?
Old 09-28-2017, 11:24 AM
  #179
Cwarta's Avatar
Thanks Rk, I can't wait either! I gotta hurry, it's cooling off here :/
Old 09-28-2017, 01:25 PM
  #180
ryeguy2006a's Avatar
Very cool build, just read through all the pages. Nicely done.
Quick Reply: Project Nova - The quest for 1000hp VS s480 l33 347
