Using abase tune with different injecters with holley dominator
Fuel Injector Information - Set - Off Time
Description: The injector off time curve (or dead time) is basically the effective time where there is no flow between the time an injector is commanded open and closed. This is specific to every injector as well as the system operating voltage. Pressure also affects this number. The 1x16 curve in the software accounts for varying system voltage.
Holley includes a sheet that has this data for all of the injectors Holley offers as well as some other commonly used injectors. If this information is not entered correctly, the base table fuel flow numbers will not reflect what the real fuel flow is. Also if the system operates under different voltages, system stability can be affected, especially at idle. Note that injector information is available in the contents section “Appendixes” in your software.
https://forums.holley.com/showthread...ctor-Dead-Time
Even doing that though, I still need the correct settings for the injectors. I used the info on that link to adjust the off time on the injectors. Now the car wont even start. haha Plus realized my yellow top took a crap on me. I didnt think it would be so hard to find the correct info for the deka 80's. Seeing as how many thousands of people run them. lol
