New forged motor question?
About the topping off of the coolant....
Pop the upper radiator hose off and fill the block/heads from there. Then pop it back onto the water pump port. Then again, top off the radiator. Then, with the radiator cap off, start it up and stand there until you see the coolant start to flow....T-stat opened.....when the level drops top it off immediately. Then stand there and wait for it to open a second time and top it off again. Do it a third time if you need to if the level keeps dropping.
Make sure you don't sit there and over heat while waiting for it to open the first time, there could be an air bubble on the engine side of the t-stat and won't ever open.
If this happens, as the engine is idling, squeeze the upper and lower radiator hoses rapidly many times each, this should move the air bubble through the t-stat and allow the hot coolant to touch it so it will open. Once it opens one time......you're good, just keep topping it off as I said above.
This is also a good time to stop using Dexcool and go GREEN coolant. I did this many years ago and my engine absolutely runs cooler all around. And it stays very clean......
You can also try to pull the PCV vacuum line off the intake vacuum port and cap the vacuum port off. See if that same smoke comes out of the oil filler neck with the cap off. If its stops coming out you have a bad PCV valve thats stuck open.
When will you take it for its first drive? 20-30 min drive will burn all the moisture that might be present in the crank case.
