Staggered turbo setup
And a controller to control when the valves open
And a million miles testing to ensure smooth transition from 1 turbo to two.....
Then you can think about the nice to haves:
Speed senor on both turbos so you can actually see what they are doing and map engine rpm, throttle position, boost, maf flow, turbo rpm,.....
Electronic actuators for valves
Again more testing as as soon as you change anything it will impact the system.
There is a reason that NO OEMs use sequential turbos on any of there gas powered cars (even BMW who know how to do it on a diesel)! It's too bloody complicated and NOT needed with decent turbo selection and optimised engine config.
You if really want instant spool with a turbo setup (assuming you need it) then use a little N2O to light it off.
Don't get me wrong I would love to see it working in practice. But I think there are just too many hurdles to jump if the amature guy. As said before even OEMs do t bother with it these days. Porsche went VGT even though there weren't turbos out there that could take the heat of gas engines. Even the hyper cars haven't bothered with VGT.
I have set up compounds on 4 bangers, diesels, and petrol V8s. They work great when done right.
