new best with traction issues.
Old Jul 10, 2017 | 10:19 PM
3 window's Avatar
Originally Posted by Cwarta
Following this, having a lot of trouble hooking my dads ls1 nova on the street, and just about finished with my turbo nova. Dads car with full Calvert suspension wiouldmseperate the rear so hard it would top out he shocks. Put some double adjustables on and it helped by slowing it down but still lays black marks heavily. Hooks great at the track.
awesone runs Mike
Once you get to a certain point, hooking on the street is gonna be extremely difficult without some sort of power management. Just have to get good at the variable foot feed!!!
Old Jul 11, 2017 | 11:43 AM
a05c's Avatar
The 275's will be faster on a prepped surface. The slick is going to work better and be much more forgiving.
If you're going to be on a marginal surface, the pro bracket radials give kinda the best of both worlds. They'll also work much better on a marginal surface than a 275 Pro.
Old Jul 14, 2017 | 09:22 PM
LS1NOVA's Avatar
Double adjustable Vikings all around and a pair of Pro Bracket Radials are what you need! Good job busting into the 9's!
Old Jul 14, 2017 | 10:47 PM
Sleeperls's Avatar
Cast s480?.
Bout to turn mine up to that 17ish pounds. Only likes to go 130mph tho
Old Jul 14, 2017 | 10:54 PM
Game ova's Avatar
Originally Posted by Sleeperls
Cast s480?.
What you weighing in at young fella? Should be pulling better than that.....depending on weight... and other factors.
Old Jul 15, 2017 | 06:28 AM
yenkomike's Avatar
yes cast s480 race cover ,83 mm turbine ,1.25 t4 housing.
the 3.23 gear and 28" tire make it run on the big end.
Old Jul 15, 2017 | 07:42 PM
yenkomike's Avatar
picked up a set of 29.5 by 9" slicks today and I want to try them at my local no prep track. should help a ton.
Old Jul 15, 2017 | 08:57 PM
Bad Apache's Avatar
They should make a huge difference. After using drag radials, I'm spoiled. Don't miss the mushy feeling of bias slicks at all. As stated though, the drag radials have been tougher to make stick all the time. Sometimes they are great, others they suck. No rhyme or reason seemingly. Apparently my car doesn't "Bitch-slap" them into the track either, lol.
Old Jul 16, 2017 | 06:06 AM
yenkomike's Avatar
with the old slapper bars my car whould dead hook any tire I had on it for a car or so then break loose if the track was slick. with the srd bars it works good everywhere except the first car length. it feels good and stable but I just cant get the hit or separation like the old slappers.
Old Jul 16, 2017 | 12:04 PM
vinceI's Avatar
You were most likely spinning when the shock topped out. Adjustable shocks probably would have made a big difference.
